2010 F150 Oil Leak
Old 10-23-2015, 11:43 AM
Leslie Alford's Avatar
Leslie Alford
Leslie Alford is offline
2010 F150 Oil Leak
I'm glad I found this thread!! I have a used 2010 F150 that I bought in February of this year, approximately 76K miles. The first leak I had (that I thought was oil) turned out to be that the rack & pinion needed to be replaced, which the dealership took care of. Now I notice another leak!! I took my truck to the shop where I normally get the oil changed & was told that the oil pan & plugs are all good. That leads me to believe it's the transmission, but there's no dipstick for me to check! The fluid stain on the carport is about a foot wide & twice as long...kind of a reddish brown color. I didn't buy my truck from any Ford dealership and I know that taking it to the dealer I bought it from will be a waste of time. Should I take it to the local Ford dealership to be looked at & fixed? I'm a single Mom & have a limited income, plus my truck is my only way to go.
Old 10-23-2015, 11:45 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
Originally Posted by Leslie Alford
I'm glad I found this thread!! I have a used 2010 F150 that I bought in February of this year, approximately 76K miles. The first leak I had (that I thought was oil) turned out to be that the rack & pinion needed to be replaced, which the dealership took care of. Now I notice another leak!! I took my truck to the shop where I normally get the oil changed & was told that the oil pan & plugs are all good. That leads me to believe it's the transmission, but there's no dipstick for me to check! I didn't buy my truck from any Ford dealership and I know that taking it to the dealer I bought it from will be a waste of time. Should I take it to the local Ford dealership to be looked at & fixed? I'm a single Mom & have a limited income, plus my truck is my only way to go.
should be a dipstick, top of engine, towards drivers side, mostly towards the back of the engine.
Old 10-23-2015, 11:47 AM
Leslie Alford
There's only one & it's for the oil.
Old 10-23-2015, 12:18 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
ah. missed that is it a an F150. and a 2010.. this section is for 2011 and up Superduty (F250 and up)
the F150 section is
2009 - 2014 F150 - Ford Truck Enthusiasts Forums
I see that for the 2010 F150 5.4L there is no tranny dipstick.
Old 10-23-2015, 05:18 PM
Tom's Avatar
Tom
Tom is offline
Hi Leslie, welcome to FTE!
Just moved your post into its own thread in the F150 forum. You'll get some better responses down here.
Old 10-23-2015, 05:50 PM
brcman's Avatar
brcman
brcman is offline
use caution
Be careful, I would not drive it until you determine that is is NOT trans fluid. There is a multipage post on here and has been noted on other sites and there is a video on youtube. There is a wire bundle passageway into the front of the transmisiion that has a rubber "O" ring seal. That seal has been a real problem, you actually do not know how much fluid has leaked if that is what is leaking and therefore may damage you transmission if it is too low and you drive it. This happened to me, mine had a washtube sized pool of fluid on the garage floor-maybe a pint of fluid. However, I had driven 200 miles continuously when I parked it and therefore did not know how much had leaked prior to parking so I called and had it hauled in to the dealer. It really looks like a mickey mouse way to keep fluid from leaking to me!
Oldstuff
Old 10-24-2015, 06:50 AM
SBV45's Avatar
SBV45
SBV45 is offline
A leak of that size is cause for concern. If it isn't engine oil, it could be trans, differential, transfer case (4WD), coollant or AC condensation. If it was any of the other fluids like brake or power steering you would probably know it.
My 09 Explorer always leaves a trail of condensation from the AC. I have put some on my finger and smelled it to make sure it isn't trans.
I would take it directly to my favorite reputable mechanic shop right away.
Old 10-24-2015, 05:00 PM
meborder's Avatar
meborder
meborder is offline
There is a dipstick, bit it is only accessible from under the truck
https://www.ford-trucks.com/forums/1...er-change.html
There was a tsb that covered a leaking transmission bulkhead connector, and by all reports it leaks pretty badly.
I'd check with a dealership to see if this can be fixed under the powertrain warranty.
Old 10-25-2015, 04:35 PM
john188971's Avatar
john188971
john188971 is offline
I had this exact same issue. For me it was the connector in the back of transmission. Fixed under warranty. There is a port right next to the exhaust running down the passenger side of transmission. Unscrew it and check level. Mine was low. I put 1.5 quarts in and took it to dealership. It's tough to check fluid cause it has to be operating temperature. So exhaust will be hot.
Old 10-26-2015, 08:32 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
...The fluid stain on the carport is about a foot wide & twice as long...kind of a reddish brown color. I didn't buy my truck from any Ford dealership and I know that taking it to the dealer I bought it from will be a waste of time. Should I take it to the local Ford dealership to be looked at & fixed?...
Welcome to the forum, Leslie! Getting your truck to a Ford Dealership is definitely a wise next step. If you need help after getting a diagnosis, I'll be happy to look into some options for you. Keep us in the loop.
Crystal
Bassboatman
2017+ Super Duty
26
04-26-2019 01:11 PM
tarantulakeeper1
01-21-2012 08:51 PM
WH90
03-05-2011 01:22 AM
radracer17
04-16-2005 12:34 PM
rmilchman
02-05-2003 11:38 AM
Quick Reply: 2010 F150 Oil Leak
