2 barrel carb on my 84 300 66?
Welcome to FTE!
What is your intended application? Hauling gravel up mountain grades, or zipping around empty? If it's the latter, does your engine have a conventional distributor with weights and springs? While replacing a carburetor with a bit larger one is possible you may not get the results you want. Re-curving the distributor advance though, may be just what you're looking for.
It's basically just changing when and how much the engine timing advance comes in at different RPM. OEM advance curves are pretty anemic. This doesn't cost much of anything either, other than time. In your situation this is the way to go versus a bigger carb. That may make it run worse overall believe it or not.
Now to answer wade108194's original question.
As far as the 2V carb swap goes there are a couple different ways to accomplish this. If you are working with a limited budget then an adapter on the stock intake is possible. But this will only give you limited gains due to the fact you are still feeding the engine through the 1V carb opening in the stock intake.
The better option is an Offenhauser C-series or Clifford 4V intake with a 4V to 2V adapter and then run an Autolite 2100 2V carb.
But you would be wise to consider swapping out the stock exhaust manifold at the same time. Swapping to a pair of EFI 300 exhaust manifolds (came stock on 87-96 EFI 300's 4,9L ) will give you the best bang for the buck along with 2V carb swap. These are basically cast iron shorty headers. When you improve the flow into the engine on the intake side you also want to improve the flow out of the engine on the exhaust side.
Do the above modifications along with a Duraspark II distributor/ignition swap ( if yours doesn't already have it ) and you should have a good reliable set up that makes decent power.
shortwide
06-30-2014 02:12 PM
monkey jason
13
11-22-2013 07:17 AM
agapewood
06-06-2010 09:52 AM
