carter carb help
Old Jun 5, 2010 | 07:44 PM
agapewood's Avatar
agapewood
carter carb help
I just got a straight six, and it has a carter carb on it that is computer controlled, the truck that it is going in has none of the electric components.
I need help. Please tell what model carburetor I need YF, YFA
and where the best place to order one from
Old Jun 5, 2010 | 08:10 PM
Franklin2's Avatar
Franklin2
I went to Car-Part.com--Used Auto Parts Market and plugged in a 1980 f150 with a 300 six in Pennsylvania. This place said they had a carb.
1980
Carburetor
Ford Truck F100 CKID A F10024 $Call New Castle Auto Wrecking, Inc. USA-PA(New-Castle) Request_Quote 1-800-245-2226 Request_Insurance_Quote
You could also try the parts store. Just try to stay with a 300 in the early 80's that does not have a electronic carb. You need to make sure also they will bolt on your intake.
Also do you realize the distributor on a engine with a electronic carb also needs the computer to work? So you will need a distributor also.
What happened to the old engine that was in the truck?
Old Jun 5, 2010 | 08:19 PM
Franklin2's Avatar
Franklin2
Here's some more info on the carter carbs.
THE CARBURETOR SHOP / Carburetor Identification
Old Jun 6, 2010 | 06:42 AM
agapewood's Avatar
agapewood
The old engine got toasted, my friend was driving it home, and the molley distributor melted down and caught the fuel line on fire. The truck is ok but the engine needs a list of new things. Plus it was a 400 over bored that only got 5mpg, for my work i need something a little better.
as far as the distributor I have not got to it yet. Moneys tight so it probably be from the junk yard
Old Jun 6, 2010 | 09:52 AM
JimsRebel's Avatar
JimsRebel
You can get a Duraspark 2 distributor on ebay, Item number: 220524675695
$55 free shipping, this is a new part with cap and rotor.
carb..... Item number: 260484435174
If money is tight, use the carb you have and spend your money on converting to a Duraspark 2 ign system.
https://www.ford-trucks.com/forums/9...-ignition.html
What year truck do you have?
I would guess the 300 engine is 84-86 unless it is from CA
