Trailer Shocks?
Old Oct 22, 2015 | 08:10 PM
Optimistic Paranoid's Avatar
Optimistic Paranoid
Trailer Shocks?
Complete trailer towing newbie here.
I've been doing a lot of research. I've noticed that no trailers seem to come with shock absorbers. But Monroe does sell aftermarket shocks for trailers.
Have any of you added shocks to your trailers?
If so, why?
Did they succesfully solve whatever problem you were trying to correct?
Thanks.
Regards
John
Old Oct 22, 2015 | 08:27 PM
RV_Tech's Avatar
RV_Tech
I installed shock absorbers on our fifth wheel to reduce the chucking. They did not completely eliminate the problem, but they did greatly improve things.
Why are you considering them for your trailer?
Steve
Old Oct 23, 2015 | 03:33 AM
Optimistic Paranoid
I'm not really considering them. I'm an old auto parts guy, and I remember seeing them in the catalogs. I'm basically just curious why they're not used more. I find it interesting that they are absolutely necessary on the tow vehicle, but apparently not at all necessary on the trailer. I'm the grown up version of the kid who's always asking: "But WHY?"
Old Oct 23, 2015 | 04:59 AM
Just Strokin's Avatar
Just Strokin
Most times, no one is riding in the trailer, so the ride is usually not a concern as in the tow vehicle. Shocks on a car or truck are to smooth out the ride for the occupants. Also with the trailer axles in close proximity to each other, you don't get the wheel drop in to potholes nor the rise of the wheels over bumps like in your truck or car that need to bee dampened.
JMHO
Old Oct 23, 2015 | 06:50 AM
RV_Tech's Avatar
RV_Tech
No one in the trailer and the trailer plays follow the leader.
Steve
Old Oct 23, 2015 | 09:23 AM
Irelands child's Avatar
Irelands child
Every trailer up to the current 2014 we have owned has had shocks - even a p'up. This one has a Morryde urethane gadget in the equalizer that's supposed to smooth out the ride and so far seems to do the job. If anyone feels the need, Dexter offers a 'kit' to add shocks.
Oh, and in NY State, you can legally ride in a 5er as it's considered an 'articulated vehicle', the same as a tractor trailer rig and locally for the Saratoga track, large horse trailers have help in them. I rode in our long gone Kountry Aire 5er once when we had to 'go' and I had a severe case of food poisoning - not recommended - ever
Old Oct 23, 2015 | 09:33 AM
RV_Tech's Avatar
RV_Tech
Dave,
Travel trailers or fifth wheels?
Old Oct 23, 2015 | 09:55 AM
wrvond's Avatar
wrvond
There are a lot of misconceptions out there concerning what shock absorbers do and do not do.
The spring portion of the vehicle (or trailer) suspension is what absorbs the force of impact between the road surface and passenger (or dishes), as do the tires to a lesser extent.
Shock absorbers dampen the action of the springs, preventing oscillations that could grow into out of control vehicle bouncing. Shocks, in effect, push the wheels back down into contact with the ground.
Without getting into a lot of esoteric physics and stuff that makes my punkin' little head hurt, trailer suspension is generally (relatively) stiffer than passenger vehicle suspension, and, as pointed out earlier, are being pulled, rather than driven. This goes a long way toward damping up and down oscillations too, though I'm sure you've seen the occasional utility trailer bouncing merrily down the road behind an apparently oblivious owner. That situation occurs when the trailer is unloaded and has no weight to counteract the bouncing action of the springs and tires.
Old Oct 23, 2015 | 10:26 AM
Irelands child
Originally Posted by RV_Tech
Dave,
Steve - The ancient Viking p'up even had some real dinky shocks as well as the Sunline TT. There was another TT that I can't remember the name (something-Lite) which also had shocks The Kountry Aire and Titanium 5ers as well had them.
The Titanium forum had a thread a few years back. As I recall, if those had had shocks, they were the pre-Lippert (late 2008) frames.
Old Oct 25, 2015 | 08:25 AM
CGMKCM's Avatar
CGMKCM
My Airstream has shocks and I could tell when they needed to be replaced. The contents of the trailer now stay in place.
Old Nov 3, 2015 | 04:00 PM
Garyl53's Avatar
Garyl53
I am about to add the Lippert Shock kits (shocks, brackets, spring plates, etc.) to our rear kitchen 5vr. We hope it will help keep things from bouncing around too much in the cabinets. We also hope it will reduce some of the chucking we are experiencing now. I have to come up with a solution to get around an existing slide-out gear connecting shaft that is interfering with the placement of the bolt-on upper shock brackets first!
Old Nov 3, 2015 | 04:03 PM
RV_Tech's Avatar
RV_Tech
Lying underneath and lagging in the brackets is a total bear. I did it on our last year and had to move a fresh water tank bracket.
Old Nov 10, 2015 | 09:22 PM
Big-Foot's Avatar
Big-Foot
My fifth wheel triple axle toy hauler has shocks at each wheel...
I left a bar of soap on the soap tray in the shower about 30 minutes before we hit the road. 500 bumpy miles later we stopped for the night. When I took my shower the next morning, I realized the soap was still there where I left it.
I do have a bit of chucking but it's not terrible or bad enough to cause me to buy a cushioned hitch.
oxt127
All Things Towing
Dec 26, 2017 10:09 AM
sundvl76
All Things Towing
Dec 14, 2011 08:14 AM
amdriven2liv
All Things Towing
Feb 26, 2011 07:36 AM
dinosaurfan
All Things Towing
Jul 7, 2001 06:36 PM
