shock absorbers
Old May 8, 2001 | 10:22 PM
dinosaurfan's Avatar
dinosaurfan
shock absorbers
Am I the only one who wonders why trailers generally do not have shocks? Wouldn't this help your trailer stay under control as you roll along? One of my trailers, made from the back half of an old truck, still has it's shocks and it pulls nicer than lots of other trailers I've hauled. What do you'll think? DF
Old May 10, 2001 | 08:22 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
shock absorbers
DF, I never really thought about it, but what a great idea. I guess that trailers usually don't have them, because nobody rides in 'em.
Might be a good application for a horse trailer though. Might make long trips less leg numbing for the passengers and help to dampen the shifting of live weight.
Old May 10, 2001 | 02:55 PM
ripf350's Avatar
ripf350
shock absorbers
I've wondered the same. I have seen ads for a company that sells add on shock kits.
Rip
Old May 10, 2001 | 09:30 PM
elliott's Avatar
elliott
shock absorbers
Cost. The upper priced 5th wheel campers have them, some of the cheaper ones just have the brackets, so shocks can be added. Bob
Old May 12, 2001 | 06:37 AM
bluesky's Avatar
bluesky
shock absorbers
For trailers like mine that have only a leaf spring suspension, Monroe manufactures an "RV Retrofit Kit". I have saved a link to a web page where you can download the kit installation instructions (in Adobe Acrobat format.)
It's on my "wish list", but before I order it I would be a lot more comfortable hearing from anyone who has done the actual installation and.
The link is: http://www.tenneco-automotivehd.com/rv_retrofit.htm
Dino
Old Jun 18, 2001 | 12:35 AM
camperbob's Avatar
camperbob
shock absorbers
I tow a 24 foot Komfort with shocks on it. It came that way from the factory. I used to tow a Wanderer without shocks, yes they do make a difference. Happy towing !
Bob.
Old Jun 22, 2001 | 12:02 PM
copeina's Avatar
copeina
shock absorbers
I have built several utility trailers over the years, and nearly all of them have included some type of shock or damper system.
The shocks keep your trailer on the ground. It's as simple as that.
Another setup that works not badly is to attach coil springs to your axle bracket and the trailer frame directly above. This seems to control the funkiness at train crossings, etc as well. The simplest form of this I have seen is a guy who just welded the coils at each end right where he wanted them. Sooner than later though, the welds cracked and now he's back to just leaves.
Hope that encourages some to go out and do it. I guarantee it's easier than picking up the pieces after you loose your trailer on the highway!
Kris Taylor
"Give me a welder, we'll set the world on fire!"
Old Jul 7, 2001 | 12:18 PM
JazzyJAC's Avatar
JazzyJAC
shock absorbers
Because most trailers use leaf type spring systems, extra damping devices are often not needed. Technically, shocks dampen the harmonic (up and down bouncy) motion of a mass (the trailer) over the springs, in order to prevent unpredictable motions of the trailer from occuring. Leaf springs, because they are binded layered sheets of steel, supply a good amount of damping natuarally due to the friction between the sheets. The damping in a leaf spring is usually enough to serve the purpose of most trailers.
Old Jul 7, 2001 | 06:36 PM
BMc's Avatar
BMc
Former Vendor
shock absorbers
