Code 212 dim check engine light
Old Oct 16, 2015 | 11:40 AM
charjr's Avatar
charjr
Hi I have 92 ranger with 3.0 v6 in it.
It flashes out code 212 ive replaced the ICM and checked the spout connector for corrosion but it still flashes out 212 and has a rough idle no power on acceleration condition. Any help would be greatly appreciated on where i should go.
also when the idle starts acting up the check engine light stays real dim and if you rev it it will get brighter
Old Oct 17, 2015 | 10:30 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Good idea to have checked the spout connector for corrosion.
Did the problem come about suddenly after some event, or slowly over time????
The dim CEL may be a clue, so check the quality of the battery to engine & body ground connections. They need to be clean bright & tight.
Keep us posted on your trouble shoot.
Old Oct 17, 2015 | 10:56 AM
charjr's Avatar
charjr
Originally Posted by pawpaw
Welcome to FTE.
It actually turned out to be the PCM their was corrsion in on the bored and resistors broke off.
Old Oct 17, 2015 | 12:40 PM
pawpaw's Avatar
pawpaw
OK, good find, fix, feedback & to hear your trouble shoot came to a successful ending & your on the road again. Yup the ECM was on the suspect list too, after the battery B+ & B-/ground connections would likely have panned out.
cdestuck
2004 - 2008 F150
Jan 2, 2014 11:25 AM
Junior81
Apr 17, 2013 08:46 AM
XDAndy
Nov 18, 2010 11:12 AM
tobacco farmer
Apr 11, 2010 07:07 AM
okcexpo
Aug 20, 2003 12:03 AM
