2007 Ranger P1633 Code
Old Apr 16, 2013 | 08:13 AM
Junior81's Avatar
Junior81
My check engine light came on the other morning after a rain storm. I took it to Auto Zone and they put their reader on it and come up with P1633 code. (Keep alive memory (KAM) voltage low).
The next morning the light was off. Couple days later it rained again and the engine light came back. Took it back to Auto Zone and checked it again to make sure it was the same code.
Seems like something might be getting wet unless its just a coincidence that it was raining each time the light came on.
Old Apr 17, 2013 | 08:46 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Maybe have your favorite autoparts store do a no cost electrical system under load checkup, with their portable electrical system tester. If all checks out ok, disconnect the battery & pull the engine computer firewall electrical connector to see if its seal is letting water get in, or if you have wiring, corrosion, or loose fitting, bent pin/socket problem with the connector. If nothing is visible, try a wiggle/flex test on the computer connector & wiring & maybe a wet down test with a spray bottle of water, to see if you can induce the problem & narrow down the trouble spot that way.
charjr
Oct 17, 2015 12:40 PM
cdestuck
2004 - 2008 F150
Jan 2, 2014 11:25 AM
rangerchief
Mar 1, 2005 08:35 PM
tinman57
Feb 23, 2004 12:01 AM
jimmyb
Dec 2, 2000 06:39 PM
