Od light flashing
Old Oct 12, 2015 | 12:10 AM
Remmons's Avatar
Remmons
Od light flashing
03 Eddie Bauer expedition 5.4 v8. Od light is flashing setting off code for solenoid b. Tranny was rebuilt a year ago. Shop replaced solenoid a 2nd time. Drove it and light comes back on. Would an intermittent output shaft sensor be a cause? If so does anyone know what the ohms should be. Usually its after transmission is warm.If I let it sit for several hrs check engine and od light go off.Any other suggestions? Thanks in advance
Old Oct 12, 2015 | 05:44 AM
projectSHO89's Avatar
projectSHO89
Get the REAL (and current) fault codes. You will need a scan tool that specifically provides "manufacturer-specific" code support.
Old Oct 12, 2015 | 09:11 AM
Skauber's Avatar
Skauber
Buy a bluetooth scantool, such as OBDLink MX and download the FORScan app from Google Play store (5 bucks or so) or on Windows (free), it can read codes on all modules, including transmission. If you don't want to do it yourself, you need to find a workshop with a proper scantool for it, or go to the dealer.
Gwilkrrs
Apr 20, 2016 06:51 AM
luvemhot
13
Jul 26, 2013 01:21 PM
bjis
Apr 5, 2010 10:09 PM
F350long
Oct 1, 2007 09:14 AM
tfrazee
1997 - 2003 F150
54
Mar 23, 2004 06:24 PM
