Alright I got a '99 7.3 Superduty F-250 I have been overheating while pulling my 1985 Camper weights around 6K.
I put a new thermostat in still overheated.
Scenario, Rpms 2500-2700 top end trying to keep fluids moving. OD to D to 2 to 1. Run in between 1 and 2 basic on the up and flat of the road.
6-8% grade engine gets hot pull over and let it cool put it in 4 wheel helps a little bit 4 wheel at least helps keep the tranny around 180. I only have a tranny gauge, I'm using the dash temp gauge for the engine.
First is to know if it really is overheating might be a bad temp sensor.
Things that come to mind is fan clutch. Other possibilities are clogged radiator or oil cooler water pump might be bad
Further to what our freaky friend said, can you hear the fan clutch engage when it gets hot? Pretty obvious increase in fan sound when engaged. Only overheats when towing?
Pull the fan back and forth, see if the clutch is toast. Poke the serp belt to see if it is tight, bad tensioner could let it slip.
If clutch is ok most likely IMO would be blocked radiator. Over the years leaves and dead bugs build up between the fins and block air flow. Pull it out and give it a blast with water to clean the fins. Or since it is a 99 just slap in a new one, pretty sure that year did not have the oil to water transmission cooler like the later models. If you are towing you want the extra cooling for the trans.
If you end up with a new pump consider a good flush to get out all the green stuff and switch to ELC.
Radiator is good oil cooler is good put a 6.0 in it last fall.
New water pump last summer.
So leaves me at Bad Temp sensor? One time it overheated I lost a gallon of fluid out the cap. I think the sensor is correct. When it overheats the cap steams.
Bad fan clutch the fans spins all the time but it doesn't speed up when it gets hot.
There you go fan clutch the oil cooler in the side of the block not the tranny cooler
have you replaced, I would call it the, radiator cap on the degas bottle.
they can go bad and not keep the system pressurized. I remember watching a bill hewitt, powerstorkehelp.com video where he highly recommended replaceing the cap as the stock cap was not strong enough spring to work properly.
Sorry for it taking me so long to reply I didn't get any email notifications.\
The fan is not kick on it just spins at an idle speed that is it. I put a 6.0 tranny cooler in it last year cause it overheated and the tranny cooler was clogged with mud. How ever as of last year the radiator was clean.
Weird part is my fan feels solid has tension turning it by hand, doesn't have play. I was researching it and the fan clutch is good for 100,000 I have 210,000. On mine.
It only overheats when I'm pulling, and only when pulling up steep grades. I flush the system last year when I had to replace the o-ring on the bottom hose.
My bad I never did a water pump last year it was the power steering pump. Since it doesn't overheat unless under serious stress I'm going with the clutch.
How do you know If you clockwise or counter. Is that from the drivers seat or look at the truck head on
If you mean the nut on the fan clutch it is right hand threads, so standing in front of the truck turn it counter clockwise to remove. Some Fords do have left hand threads on the fan clutch, and they are stamped on the fan shroud "Left hand threads on fan". But not the 7.3.
Over time the internal tubes in these radiators get clogged with silicate drop out from the coolant. If enough of the radiator is clogged internally or in the right spot the fan clutch will never get hot enough to lock. The only way I have figured to diagnose it is to fill the radiator with hot water and shoot it with an IR temp gun out of the truck...just look for the cool spots. Of course by the time you have it out for me it made more sense to have the replacement on hand ($200) rather than put the original back in.
