Another ESOF thread discussion.
Starters, I am in the middle of some front end repairs including unit-bearing, u-joints, ball joints and seals. I noticed the ESOF hose has holes in it on the fitting when removing. My ESOF has not worked since I have owned the truck. I plan on going with a manual hub conversion, just haven't pulled the trigger on one.
My theory is to cap and remove the hoses on the vacuum pump. I also removed the broken fitting on the knuckle which leads to my question. If going with a manual lock out would it be OK to replace the barbed vent fitting with a bolt and some blue loctite instead of replacing and capping the new vent?
New vents at local dealer are $10 a piece + tax. Bolts and washers maybe $5 and covers both sides.
@hav24wheel
@hav24wheel
That sounds like a good idea, has the Wagoneer slung out any of that grease since the zerk mod? I don't see what it could hurt on a street driven rig as long as it keeps the grease in the knuckle and doesn't throw it all back out. More lube is always better in my mind.
Hasn't spit any out yet, but have to have the lockout off when filling it up so you don't over do it. Keep a eye on the axle shaft seal so you don't push it out, and when grease comes out where the axle shaft comes through the hub it's full up.
I did a mod like that on my older style strait axles too. Filled the whole hub with grease, to keep water out.
Re-did the pipe plug with Teflon tape and capped the hose at the fender well for temporary.
Attachment 289784
Attachment 289784
85F2502WD
11-14-2017 02:35 PM
sammie0126
11-24-2015 02:00 PM
L. Ward
07-02-2011 12:25 PM
