Steering column adjustment
Old Oct 7, 2015 | 08:34 AM
john jamieson's Avatar
john jamieson
Can the mounting spacer in the cab of my '64 F-250 be eliminated to allow more room between the driver and the wheel or does it involve too much fiddling with the steering?
Thanks. john
Old Oct 7, 2015 | 09:07 AM
svolpone's Avatar
svolpone
The 64 steering column uses a solid shaft that goes directly into the gear box. If you want to shorten it then you have to do some modifications to the shaft and the column body. I just redid mine, but stupidly I kept the same length, and now it's too close to my body (my wife is worried about that). Check out my thread for what I did (or, more accurately, my mechanic did). If you add a rag joint, I suggest going the distance and adding two. I will eventually redo mine to do that, and move the steering wheel farther from my body.
Old Oct 7, 2015 | 04:49 PM
jowilker's Avatar
jowilker
Steve, I'm stumped, how does one keep it the same length, and now it's to close to your body??
John
Old Oct 7, 2015 | 05:23 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Shhhh. His body grew....don't tell his wife...actually maybe that's what she's worried about...hmmm.
Old Oct 7, 2015 | 07:43 PM
john jamieson
What I was wondering if it's possible to do would be to rotate the steering box sightly. loosen and relocate the firewall mounting bolts as needed, and attach the column directly to the bottom of the dash. This would give a little more room. I just wondered if anyone had tried this.
john
Old Oct 8, 2015 | 08:19 AM
svolpone's Avatar
svolpone
John
i'm fat John. Geez, thanks for pointing that out! lol.
JNye
Jan 24, 2019 04:03 AM
Ash66F100
Jan 26, 2018 08:36 AM
hombre292
Dec 9, 2012 09:30 PM
Scratcher
Nov 28, 2010 08:58 PM
IDIDieselJohn
Jul 14, 2009 05:47 PM
