Question on 64 Slick Steering Column
Old Dec 8, 2012 | 04:43 PM
hombre292's Avatar
hombre292
I have a 64 shortbed pickup and have an issue with my steering column. First of all, the truck drives just fine.
But when I sit behind the steering wheel, I can see that my steering column is not exactly centered up. It appears to be angling slightly to my right. Does anyone know what could cause the steering column to angle like this?? Thanks. Hombre292
Old Dec 8, 2012 | 05:02 PM
garbz2's Avatar
garbz2
It is normal.
The steering box and shaft is not centered in the dash.
Garbz
Old Dec 8, 2012 | 05:14 PM
hombre292's Avatar
hombre292
I guess I should have said, as the Steering Column comes up, it is not perpendicular to the dash. It is on a slight angle to the right. Is that normal ??
Old Dec 9, 2012 | 09:30 PM
garbz2's Avatar
garbz2
Yes it is normal.
The steering box is attached to the frame. It has a integral steering shaft that runs inside the column.
Your cab may have sagged a bit or have bad front cab mounts but offset and slight angle are normal.
Garbz
ireding
Large Truck
Apr 1, 2013 05:43 PM
mark63uni
1961 - 1963 F100 Unibody
Mar 6, 2012 08:35 PM
ymurf
Mar 20, 2004 09:01 AM
19Seventy7HiB0y4x4
16
Mar 20, 2002 09:12 PM
