A/C no longer working
Old Oct 5, 2015 | 12:20 PM
neilc88's Avatar
neilc88
Hi guys,
My A/C has just stopped working and I am looking for some pointers on how to diagnose the problem.
The vent and blower still works, just no cold air coming out.
Where do I start?
Old Oct 5, 2015 | 02:22 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Have you checked to see if the compressor is turning? If it is not, check the fuse, if the fuse is good you can jump the compressor to see if it starts. if it does, check your air temp, you might have low gas which would cause the compressor to shut down. You can add gas to the system to get it operational again and then check for leaks. Both are easy and inexpensive fix. If the compressor does not turn when jumped it might be bad. Not every thing that could be wrong with the system but a good start to identifying problem.
Old Oct 5, 2015 | 09:22 PM
mikenamys's Avatar
mikenamys
check back AND front vents if compressor is running...if you get cold from one but not the other its most likely a bad expansion valve. Definitely start at the compressor first...
Old Oct 6, 2015 | 07:17 AM
neilc88's Avatar
neilc88
Last night I took Vinny G's advise and started to investigate.
1. The compressor is turning when the AC is on. It also turn off when AC off.
2. Checked the "most likely" fuses and none are blown.
3. Air temp from the front vents = outside temp. It is not cold. I only tried the front vents.
It seems like I need to refill the freon with the leak detection die.
I will have to check the back vents tonight.
Any other ideas?
Old Oct 6, 2015 | 07:22 AM
projectSHO89's Avatar
projectSHO89
Look not only at the clutch hub, look also at the bolt head on the compressor shaft to see if it's also turning.
If the system is low on refrigerant, the compressor will usually "short-cycle". Is it doing that? If not, it's not a charge level issue.
Check the lines at the firewall to see if they're cold or not. If they are not and the compressor "appears" to be operating continuously, you've most likely got an internal compressor failure, either a sheared shaft or the valves have blown. Check for that by, with the engine off, seeing how easily the compressor hub and shaft turns by hand (or with a ratchet/8MM) on the bolt head. A normal compressor will offer resistance at multiple points of a rotation, a failed compressor will turn easily throughout the revolution.
Old Oct 6, 2015 | 07:50 AM
neilc88's Avatar
neilc88
I will have to look at the center bolt and check the rear vents today.
Old Oct 6, 2015 | 09:25 AM
Vinny G-the EX man
Right on target, was going to be my next suggestions. It is basically a process of elimination. Just keep plugging away. All the best.
Old Oct 6, 2015 | 09:41 AM
neilc88's Avatar
neilc88
Can I do this with the serpentine belt on or do I need to take it off?
Old Oct 6, 2015 | 10:48 AM
mikenamys's Avatar
mikenamys
Slow down...get her warmed up with the a/c on and check your rear vents before moving on. If they are both sub-par and the compressor is running, I'd bet on just low refrigerant. Big system so it may need a can or two. My front started sucking after I replaced my rear expansion valve(NAPA has em). Now my back freezes you out while the front barely cools. Just had too much $$$ already in it so next year the front gets tackled, but with the rear it gets arctic cold in there! You could just simply be low on R134. Get a gauge next and get some pressure readings. Don't worry about the compressor just yet...no sense getting bummed out about an expensive worse case scenario when it could be a $20 fix. If it has dye in it, don't add anymore. I think overuse is what kills these systems...that and stop-leak....of course I don't like stop-leak anything...like a band-aid for a broken leg.
Old Oct 6, 2015 | 12:07 PM
neilc88's Avatar
neilc88
Ok, checked out the following at lunch time today. It is not very warm (65 degrees F) to be checking AC. Here is what I found.
1. The center bolt on the compressor is spinning when AC is on. Not spinning AC off.
2. The rear vents got cold, but the front did not get cold. Rear reading was 55 degrees out of lower vent. Front read 68 degrees ~ outside temp.
3. There was a lot of water on the ground under the AC drain.
4. Under the hood, the "T" AC line was very cold with condensation.
Where do I go from here? Thanks for the pointers?
Old Oct 6, 2015 | 03:31 PM
projectSHO89
Pursue checking the charge level. The system is working, but poorly.
Fiveacre
1997 - 2003 F150
Jul 31, 2019 09:12 AM
camper415
Nov 5, 2017 07:53 AM
cv18sro
1997 - 2003 F150
Jun 24, 2011 10:45 PM
z 97ford1
1997 - 2003 F150
24
Aug 27, 2007 11:27 PM
Judson4.9L
May 19, 2005 09:38 PM
