PSOM problem
Old Oct 4, 2015 | 03:10 PM
Sluggo55's Avatar
Sluggo55
Question PSOM problem
first time poster. I have a 1997 F250 Powerstroke automatic.
PSOM gone bad. Can I just change speedometer, and use 1996 -1997 from either gas or diesel, or any other previous year.
Old Oct 4, 2015 | 06:21 PM
madpogue's Avatar
madpogue
Any '92-'96 (or '97 F-250HD / F350) should work, gasser or diesel.
Old Oct 4, 2015 | 06:23 PM
cstempert's Avatar
cstempert
Originally Posted by Sluggo55
first time poster. I have a 1997 F250 Powerstroke automatic. PSOM gone bad. Can I just change speedometer, and use 1996 -1997 from either gas or diesel, or any other previous year.
One note: you will end up with the milage of the donor speedo
I added 10k miles to my 97!when I changed PSOM /speedo
Old Oct 4, 2015 | 06:53 PM
dixie460's Avatar
dixie460
Unless you swap the EEPROM over... then you can keep your mileage. Requires good soldering skills and of course your current EEPROM must still be operable.
Old Oct 4, 2015 | 07:02 PM
Sluggo55's Avatar
Sluggo55
Thanks that's good news lots of gas parts trucks to choose from now.
Old Oct 5, 2015 | 10:17 AM
subford's Avatar
subford
You do not have to solder. Just read the information from your old PSOM's EEPROM into your home computer and then send the information to the replacement PSOM's EEPROM.
Just requires a EEPROM reader/burner hooked to your home computer running XP OR 7.
Old Oct 6, 2015 | 07:01 AM
dixie460's Avatar
dixie460
That works too! Just figured soldering was easier for most.
People still use XP? Lol. It was actually a pretty good OS I guess... the latest I've used is 7 but I prefer Linux over anything from Micro$oft.
Old Oct 6, 2015 | 11:10 AM
subford's Avatar
subford
Yes I use Linux also but the software for the EPROM read and burner only runs on XP & 7 and older Micro$oft OS. I have 7 also but a lot of my stuff does not run on 7.
You can also change the change number of changes with the EPROM burner back to 6.
Then you can just copy the rest of the data over to the working PSOM.
Old Oct 6, 2015 | 05:29 PM
dixie460's Avatar
dixie460
What reader do you have? I see several of them for cheap...
Old Oct 6, 2015 | 05:34 PM
subford's Avatar
subford
The SP8-B Programmer:
SP8-B Programmer (Product Browse)-ÉîÛÚ˶·É¿Æ¼¼ÓÐÏÞ¹«Ë¾-http://www.sofi-tech.com/
My reader:
Old Oct 6, 2015 | 06:23 PM
Eddiec1564's Avatar
Eddiec1564
If you are good at building electronic circuits, look up PonyProg.
I use that and had no issues. I have not tired reading the EEPROM directly off the PSOM yet, but it should work.
I did finally figure out how to "000000.0" the odo but have not figured out the parity check enough to set mileage to what ever...
Old Nov 2, 2025 | 01:18 AM
Jloz's Avatar
Jloz
3rd Gear
Pm me
Can you pm me plz I have a question
Old Nov 2, 2025 | 04:34 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What person in the thread are you talking to? Why can you not ask the question here?
Old Nov 2, 2025 | 08:48 AM
subford's Avatar
subford
Old Nov 2, 2025 | 11:29 AM
Jloz's Avatar
Jloz
3rd Gear
have you figured out how to edit the hex code?
green_95
Apr 6, 2019 05:49 PM
linjer
Jan 9, 2017 08:47 PM
KKMil
Jan 18, 2011 11:19 PM
SYKOLINCOLN
1997 - 2003 F150
Dec 15, 2010 07:13 AM
