Brake Problem
Old Oct 3, 2015 | 05:15 PM
mtntop1's Avatar
mtntop1
Brake Problem
Hi all
Here is my problem.I just installed new brake shoes on the rear of my 95 F150 with all new hardware and rebuilt the wheel cylinders.I've done this many times.I bled the brakes both by pumping and reverse bleed but the pedal will only come up just about halfway.I also installed new drums.I am at a lose at this point and never had this problem.Any help would be appreciated.
Old Oct 3, 2015 | 05:57 PM
88n94's Avatar
88n94
I assume you tried to properly adjust the new brake shoes. Half a pedal isn't too bad. I would probably try to find a fairly untraveled spot and back up with one foot on the gas pedal and one foot one brake pedal and repeatedly hit the brake pedal. This way the rear brake shoes can properly self adjust. I have done this a few times. Just a suggestion. Good luck.
Old Oct 3, 2015 | 07:04 PM
mtntop1's Avatar
mtntop1
I manually adjusted the brakes until I got a drag when I turn the wheel by hand and the did the backup still the brake pedal is only half way.It use to be about 3/4.
Old Oct 3, 2015 | 07:47 PM
Phil Woolfson's Avatar
Phil Woolfson
Check fluid level (should bee within 1/8" of max) make sure vents in reservoir lid are clear, check rear adjustment and bleed. If your fluid is old (black) I'd change it.
jeep_guy48
38
Mar 27, 2015 06:15 AM
goodybrain2001
Jan 17, 2014 05:16 PM
jmgrif
Aug 7, 2012 07:21 AM
2wd79f100
Jan 14, 2007 07:17 PM
steve1147
Jan 19, 2004 09:28 PM
