low brake pedal problem
Old Jan 15, 2014 | 02:13 PM
goodybrain2001's Avatar
goodybrain2001
Question low brake pedal problem
I have a 1993 F350 none turbo diesel dual wheel rear 7.3L.Never winter driven.Replaced,2 rear wheel cyl`s,shoes,drums,2 front calipers and pads,serviced sliders bleed brakes and adjusted shoes so just to touch drums.You can stop but pedal is low.Any ideas?Vacum pump working good,lots of vacum.+
Old Jan 15, 2014 | 02:36 PM
88n94's Avatar
88n94
It can be real tricky to get those rear shoes adjusted just right, tight but not too tight. Could also be some air in the lines yet, but that will usuaully work out driving it, as long as you have some pedal which you do.
Old Jan 15, 2014 | 02:50 PM
88n94's Avatar
88n94
Actually what you might try, assuming you have a good place to do it. Go in REVERSE with one foot on the brake pedal and on foot on the gas pedal, back up slowly and keep hitting the brake pedal. The rear brake shoes should self adjust to the proper tightness.
Old Jan 15, 2014 | 02:57 PM
goodybrain2001
Question re low brake pedal
brakes are adjusted properly.tighten them up tight on purpose,pedal same
Old Jan 15, 2014 | 02:59 PM
88n94's Avatar
88n94
Did you have a good pedal before doing the work?
Old Jan 15, 2014 | 04:03 PM
goodybrain2001
Question re pedal
had problem for longest time given to me to try and figure out.
Old Jan 15, 2014 | 05:26 PM
danr1's Avatar
danr1
Solid plug the brake line ports on the master cylinder test pedal, if solid pedal the problem is down stream of the master cylinder, if pedal is soft line ports plugged the master cylinder is the problem.
If do replace it, be sure and follow the included instructions for proper bench bleeding method to avoid damaging it in the process.
Old Jan 15, 2014 | 06:20 PM
goodybrain2001
Smile Re pedal
Have changed master,think I might pinch off brake flex hoses with plastic line plyers and see if the pedal gets hard,could be flex hoses weak,if no change,repeat at rear flex hose and check pedal.just thought about this!
Old Jan 15, 2014 | 07:02 PM
rla2005's Avatar
rla2005
If this has been a long standing problem that other owners may have tried to fix it could be as simple as this: Brake Booster Pushrod Adjustment - FSB Forums
Old Jan 15, 2014 | 07:40 PM
goodybrain2001
Smile Re low brake pedal
Tks for your input,will try that tomorrow and totally forgot that the push rod was adjustable!will let you know.
Old Jan 16, 2014 | 03:04 PM
goodybrain2001
Smile re brake booster adjustment
worked perfect,thanks so much!
Old Jan 16, 2014 | 03:15 PM
rla2005's Avatar
rla2005
Glad to see it worked for you. Sometimes it's the simple small things like that cause the biggest headaches.
Old Jan 16, 2014 | 04:36 PM
danr1's Avatar
danr1
Yup that was good thinking.....was denied leaving rep points as usual......, when troubleshooting and doing so after others before ya gotta check everything. There is no way to know what they might have screwed with!
Old Jan 16, 2014 | 05:02 PM
rla2005's Avatar
rla2005
X2
Old Jan 17, 2014 | 05:16 PM
goodybrain2001
X2
Yes crazy!
mtntop1
Oct 3, 2015 07:47 PM
stonemason
Jan 18, 2012 11:32 AM
2wd79f100
Jan 14, 2007 07:17 PM
Sycostang67
Feb 16, 2005 01:11 PM
