I think I ordered my deflectors from IDcariD, or something like that. The packing slip came from Onyx Enterprises. I had a bit of the same problem, but then just sat there and looked at the situation until I realized that I had the start point too far down and it was jamming the window rubber. I got the deflector out without breaking anything, reset the deflector, and the window would almost go all the way up. I'd go around the deflector, beat on it a little bit, lower it and then wipe a little water on the edge. Eventually the window went up and down with no problem.
I was used to the old style with an adhesive contact and I found the new style a bit confounding. But once I got the driver's side right, the passenger side went on with no problem. I should go into business. Every once in a while even a blind pig finds an acorn.
YES, I'VE FOUND ACCESSORIES TO BE DIFFICULT. BUT I'VE FOUND THEM: BUG DEFLECTOR, DASH MAT, SEAT BELT EXTENTION(SO THE DARNED THING DOESN'T GO OFF WHEN I'M CRUISING LOCALL), MUD FLAPS, SEAT COVERS, ETC.
WE NEED TO REMEMBER THAT THIS IS A RELATIVELY NEW VEHICLE IN THE US AND THAT WE ARE THE FIRST SCOUTS.
