302 engine shuts off at intersection
Old Sep 28, 2015 | 04:07 PM
papabills54's Avatar
papabills54
what do I need to look at for this problem? I have a 54 Ford pick up with a 302 and T-5 5 speed. and just recently when I come to a stop the engine will shut off. It starts back up again but don't know where to look for this problem. My tack shows about 650 at idle and it doesn't do it all the time. I have an electric fuel pump and a ford electronic distributor. I would think if either were a problem it would do it all the time. ??? any help would be appreciated
bill
Old Sep 28, 2015 | 04:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
High fuel level in the carb sloshing? or too low and it starves the jets?
Old Sep 28, 2015 | 04:29 PM
carnut122's Avatar
carnut122
Try setting it at a higher idle speed?
Old Sep 28, 2015 | 04:45 PM
Fomoko1's Avatar
Fomoko1
Does the idle speed fluctuate? If so then it may be a vacuum leak.
Old Sep 28, 2015 | 07:37 PM
papabills54
Ok, I'll check for vacuum leaks and set up the idle to 750. It does appear to be fluctuation a little so maybe. thank you.
Old Sep 28, 2015 | 08:43 PM
ZOOT's Avatar
ZOOT
What happens when you hit the gas when it's dying ? Might answer some carb questions. Don't think it's the pump or it wouldn't start right up again. What did you get the engine and trans out of ?
Old Sep 29, 2015 | 10:02 AM
Flat Ernie's Avatar
Flat Ernie
The other thing that happens when you pull up at a stop is your alternator drops below cut-in voltage. This can cause a problem if you have a coil that is on its way out or, as I had, a pickup reluctor in the distributor. However, these often won't start back up as they're generally also heat-related failures with partial internal shorts that manifest only with heat AND the drop in voltage.
I'd check vacuum leaks and fuel first. A slightly higher idle wouldn't hurt - be sure to check idle with the largest electrical load you will likely have (lights, AC, etc) all on. I like the idle for manual transmission cars to be 700-750 and automatic 650-700 in drive and brake held.
Russ t fender
Dec 5, 2015 10:46 PM
77 forddddd
Mar 24, 2012 08:09 PM
skoalboy87
Jan 24, 2008 01:12 AM
grelsner96
Sep 30, 2007 08:52 PM
crawlfish
Jun 8, 2006 05:46 PM
