idle speed
Old Jan 23, 2008 | 07:51 PM
skoalboy87's Avatar
skoalboy87
idle speed
i have a 1991 f150 4x4 woth a 302. at idle sped it sits very low and almost wants to stall. how do i chage the idle speed? thanks
Old Jan 23, 2008 | 08:10 PM
kcb37's Avatar
kcb37
Is your check engine light on? It should be fuel injected. Which means you can't really do a whole lot. Check your vacum lines. My books say you can's adjust the idle at all on these. I know on a Chevy you can sometimes turn the TPS on it's mounting screws to get it adjusted right. But I don't see one at all on these.
When was the last time you did a tune up?
Old Jan 23, 2008 | 09:32 PM
skoalboy87's Avatar
skoalboy87
engine light isnt on. and i just got it so god knows when that was
Old Jan 23, 2008 | 09:39 PM
kcb37's Avatar
kcb37
I would check your vacum lines and give it a good tune up.
Then see what it does.
Old Jan 24, 2008 | 01:12 AM
nighthawk285's Avatar
nighthawk285
One important thing DON'T MESS WITH THE IDLE SCREW!!!!! I can't stress that enough. The fuel injection system is run with that at a specific spot, so messing with it makes it really hard to get everything back in sych again (speaking from experience, did it before someone told me not to).
It should idle somewhere around 700-850RPM, do you have a tach? When was the last time a tune up was done on it?
Will it just not idle, or does it do this all the time?
Jim TN
Mar 1, 2015 01:51 PM
janvan.1
2004 - 2008 F150
Apr 25, 2010 05:32 PM
crescentwrencher
Apr 4, 2008 08:37 PM
keith3765
Sep 30, 2007 01:34 PM
BlueZack
Nov 29, 2004 02:18 PM
