Fire Wall Pad Question
Old Sep 28, 2015 | 03:55 AM
Crop Duster's Avatar
Crop Duster
Is it possible to use a 1967 firewall pad in a 1965 2wd? The reason I ask is I don't want to pay $250 for one of the ABS plastic ones when you can get a 67 for $80.
Old Sep 28, 2015 | 04:31 AM
jowilker's Avatar
jowilker
Don't see why not, as the firewalls are basically the same 65-79.
John
Old Sep 28, 2015 | 05:26 AM
Crop Duster
Thanks! I think I will order one and see how it fits. From looking at the pictures it seems the only big difference is where the wiring goes through the firewall.
Old Sep 28, 2015 | 10:32 AM
john jamieson's Avatar
john jamieson
Look forward to hearing how it fits as I need one for my '66.
john
Old Sep 28, 2015 | 01:59 PM
daveengelson's Avatar
daveengelson
john
Me too.
See companion thread re: rear cab mount support.
Old Oct 8, 2015 | 12:18 PM
Crop Duster
Just received the firewall pad. I got one on e-bay, http://www.ebay.com/itm/191496187169?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITIt is made of what appears to be 3/32 inch thick neoprene rubber with a 1/2 inch thick jute backing. I did a trial fit on a fire wall out of a parts truck and I think it is going to be just fine. It seems everything on the passenger side is exactly right all the holes for the heater are OK. On the drivers side the steering column and the brake mount seem to be in the correct spot. The wiring is a different story. None of those holes line up and will have to be cut for the 65 wiring and the other holes plugged. But for $79 with free shipping it will do the job.
Old Oct 8, 2015 | 05:51 PM
Becky_is_a_66's Avatar
Becky_is_a_66
That looks like a good deal to me; I bought the expensive ABS plastic repop for the 65-66 and still had to modify and trim to get it to fit correct. The ABS is much harder to modify then the material on the one you purchased (switched to power steering so column alignment was the worst part). Still have to do the other truck so look forward to hearing when you finish the install.
Old Oct 8, 2015 | 06:08 PM
daveengelson
Seems reasonable to me, despite some slight modification, considering the difference in price, certainly an improvement over the spindled and mutilated firewall pad that is currently in the truck. I did purchase the 'firewall pad' from DC at least 15 years ago and it still looks in great condition. Having said that, don't come cheap but I can be had.
dwhawkins89
Mar 22, 2015 04:33 PM
ferguson777
Oct 21, 2009 06:44 PM
camperspecial65
Jan 30, 2008 06:16 AM
camperspecial65
Aug 15, 2005 07:12 PM
greystreak92
1978 - 1996 Big Bronco
Oct 30, 2003 10:16 PM
