still on the hunt...
Old Jan 27, 2008 | 03:54 PM
camperspecial65's Avatar
camperspecial65
for a good 65/6 2wd firewall insulation pad...in case anyone runs across one...
- cs65
Old Jan 27, 2008 | 04:04 PM
William's Avatar
William
Unlikley! Carpenter sells a nice ABS version for about 150.00 or so. You can make one out of the black fiber board found at Home Depot or I plan to use "Lizard Skin" sound deadner. I'll spray it on since I block most of the original holes in the fire wall like those for wiring connectors, choke cable and accelerator linkage.
Old Jan 29, 2008 | 09:16 AM
airharley's Avatar
airharley
I believe concours ford parts in Nevada has them, I have the truck and fairlane catalogs at home and can't remember which one has them but they aren't very expensive compared to some others.
Old Jan 29, 2008 | 12:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by camperspecial65
for a good 65/6 2wd firewall insulation pad...in case anyone runs across one...- cs65
Just so you know what fits...and what doesn't.
C5TZ-8101670-A .. Firewall Insulation Pad
Fits: 1965/66 F100/250 2WD
The illustration (such as it is) is on page 15 of the interior trim section.
EDIT: concoursparts.com has an online catalog, but doesn't show one for a truck.
Old Jan 29, 2008 | 12:37 PM
jowilker's Avatar
jowilker
Bill, What is the difference in the 65/66 and 67/72 since the firewall is the same?
thanks
John
Old Jan 29, 2008 | 01:17 PM
NumberDummy
Originally Posted by jowilker
Bill, What is the difference in the 65/66 and 67/72 since the firewall is the same?thanks John
Heck, I dunno, but Ford shows myriad different part numbers for the insulation pads:
1967/69 & 1970/72 F100/350 2 or 4WD (Except Ranger & Ranger XLT): C7TZ-8101670-A
1970/72 F100/350 Ranger & Ranger XLT: D0TZ-8101670-A = BLUE / -B = GREEN / -C = BLACK / -D = RED.
Waaaal....you HAD to ask!
Old Jan 29, 2008 | 03:56 PM
jowilker's Avatar
jowilker
I know after 73 they changed the hole with the heater blower under the hood.
Maybe one has a cut out that the other doesn't.
John
Old Jan 29, 2008 | 06:04 PM
es2rider's Avatar
es2rider
I am in the process of restoring a low mileage garage kept 1965 F100. Everything that came off of the truck is repairable or easily restored, except for the firewall pad.
I really tried to remove it in 1 piece, but it just crumbled to bits.
I am also looking for one.
Good luck finding one, Doug
Old Jan 30, 2008 | 06:16 AM
jowilker's Avatar
jowilker
I have an un-cracked dash pad that I am afraid to touch for the same reason.
John
Jake65
13
Apr 2, 2026 01:52 PM
camperspecial65
Aug 15, 2005 07:12 PM
StockMan
Jan 6, 2003 05:25 AM
William
May 30, 2002 11:13 AM
66worktruck
Sep 3, 2000 11:19 PM
