Alternator Questions
Old Sep 25, 2015 | 07:38 AM
kountzecobra's Avatar
kountzecobra
I am in the process of installing a Cummins 12 valve engine into a 1996 Ford Shuttle bus that I use as a car hauler. I need to fab alternator brackets and rewire so I have to choose an alternator. I have 3 choices: Dodge/Cummins Denso 120 amp, Ford 130 amp 3G, and a Leece-Neville 165 amp unit. Currently I have the Ford 3G on the 460 in the bus since the L-N had problems (turned out to be in improperly wired regulator but after installing a new internal regulator, the alternator is now in fine shape. The 3G probably puts out the most amps at low speeds which is a plus for the rear mounted A/C unit. I realize the Leece-Neville was installed in the ambulance-ready models so does that indicate their reliability and output?
Old Sep 25, 2015 | 02:19 PM
Franklin2's Avatar
Franklin2
The Leece-Neville unit was Ford's optional high output unit in the old days. I think it or the 3G would serve your needs well. So I would look at both and see which is easier to physically mount.
Old Sep 25, 2015 | 07:59 PM
kountzecobra
I am using the 130amp 3G alternator on the 460 currently in the bus and I guess it keeps up pretty well even with the condensor with all 3 fans running. Am I correct in saying that it seems the L-N alternator is build heavier than the 3G?
Spaz1461
Large Truck
Jan 30, 2018 10:38 AM
vectrex
May 9, 2012 06:43 AM
corvetzo
Aug 6, 2011 10:04 PM
projectbad78
Oct 18, 2008 08:34 PM
it175k
Oct 26, 2004 01:54 PM
