alternator
Old Oct 26, 2004 | 01:15 AM
it175k's Avatar
it175k
alternator
Do i have to worrie about getting an alternator that generates to many amps.
91 f-150 351w
Old Oct 26, 2004 | 12:27 PM
wtroger's Avatar
wtroger
Nope. The battery will only take so much and the voltage regulator will keep the voltage at correct level. The rule of thumb is never put on an Alternator that makes less amperage but it is alright to put one on that is capable of making more. I have done the swap form a 60 amp 2nd generation Ford alt to a 130 amp 3rd generation Ford alt with no problems,
Old Oct 26, 2004 | 01:54 PM
frederic's Avatar
frederic
Generally, I'd replace the regulator when replacing the alternator to a higher current unit, if the regulator is seperate. I've seen them "wig out" a few times during such upgrades just because they were marginal to begin with from age. I shouldn't be a problem, however, your car audio equipment would appreciate you being sure.
