Alternator upgrade
Old May 8, 2012 | 11:38 AM
vectrex's Avatar
vectrex
Alternator upgrade
I have an opportunity to pick up a new DBelectrical 220A alternator for a bargain. My old alternator isn't in need of replacement though. Is this the sort of thing that is good to have around? What disadvantages are there to running a high output alternator?
Also, is the FVP on the scangauge supposed to be a good representation of charging voltage?
Old May 8, 2012 | 07:34 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
thats a good name in ho alternators, so if you can afford to put it on the shelf for now do it. If you install high amp draw equipment like winches, inverters that alternator would help with the load. You should upgrade your charging lead if you were to use/buy it.
Old May 8, 2012 | 08:23 PM
BLADE35's Avatar
BLADE35
FVP follows my Volts Really Close
Havent heard of that brand Alt sounds like Curt has so probably a Good One
Old May 8, 2012 | 08:52 PM
bismic's Avatar
bismic
DCPower beats DBElectrical in quality - hands down!
Old May 8, 2012 | 08:58 PM
BLADE35's Avatar
BLADE35
I will throw my vote for DC Power Too Well Worth the Money Works great for me pushing a Stereo System I was Eating up OEM Alternators
I havent even seen a Bad DC Power alt Pop up on here yet
Everyone has had Great Success with DC Power
Old May 8, 2012 | 09:39 PM
BKM-WR3's Avatar
BKM-WR3
Another for DC power.
Old May 8, 2012 | 09:50 PM
Getsome68's Avatar
Getsome68
I had my alternator tested today and it failed the test twice so after looking around I found a new Bosch 180 amp but I see that the cables should to be changed to 2g. I'm not sure that I want to upgrade my cables right now so my question is: at what point/amp do you have to upgrade your battery cables 140, 160?
Old May 8, 2012 | 10:09 PM
bismic's Avatar
bismic
You can get a Ford 140A alternator to replace the original - no need for wiring upgrade on it (per Ford). General rulewould be - above 150A, then I would increase the wire size (or add another line).
http://www.rushpowersystems.net/?p=4
Old May 9, 2012 | 06:43 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
I replaced my stock alternator with a 140 amp db 2 years ago without any problems. He wasn't asking about brands just if he should buy it at the right price.
79FordBlake
Jan 24, 2010 11:55 AM
sciondude09
Mar 15, 2009 05:59 AM
projectbad78
Oct 18, 2008 08:34 PM
Skier041
Apr 5, 2008 11:11 AM
amulford
15
Feb 26, 2006 12:11 AM
