Occasional hard pull to right under braking, cannot diagnose. Help?
If I brake hard a dozen times, 8 or 9 will be normal, a couple times it will pull to the right but as long as your hands are on the wheel you can barely tell, and maybe once it will pull really hard. I have Hawk super duty pads and Ebc rotors with less than 5k on them and I just replaced the front calipers and hardware because I thought that was the problem.
I have no idea Wtf is wrong now. It's not even consistent. Could possibly be rear calipers (rear also has new Hawk pads and Ebc rotors with less than 3k on them) but I don't think it would pull that hard. Any other suggestions? Tire pressure is even between sides btw.
The powerslot branded calipers are just parts store rebuilds with red paint on them. So at this point I've done everything you have and more except change the hoses. And I just bought a pair of those this evening although I drove the truck today and it felt ok. I'll change them and hopefully it will solve it for good.
Changed the hoses today. Didn't drive it much afterwards but on the test drive it was braking dead centered. I could take my hands off the wheel and dive on the brakes and it tracked perfectly straight, which I don't think it's really done in quite some time, so hopefully that cures it.
The good part from this exercise is that I bled all four corners and got some really nasty looking black fluid out of there and replaced it with valvoline synthetic, and also that I slathered the pads in antisqueal (ran out last time) and got rid of an annoying speak.
sean23johnson
22
04-12-2013 04:09 PM
NChornet
06-04-2006 05:46 PM
