Od light flashing
Old Sep 23, 2015 | 09:02 PM
Remmons's Avatar
Remmons
Od light flashing
I currently have 03 Eddie bauer expedition 5.4 v8 4x4 . Last year Od started flashing on dash.Then check engine light came on. Took it to tranny shop. Put new transmisson in and solenoids in as well as internal harness. Ran great. For about 11 months no problems. The other day light came on again. Replaced shift solenoid. And light keeps coming on. If I let it sit and cool down I can reset with code reader. Fine for awhile then light comes back on once it heats up again. Not real consistent! Any ideas or suggestions? Thanks in advance. Tranny shop thinks it is a wiring harness issue. Any idea where to get one?
Old Sep 24, 2015 | 09:39 AM
alloro's Avatar
alloro
What's the code you're getting?
Old Sep 24, 2015 | 10:52 AM
Remmons's Avatar
Remmons
Shift solenoid b (electrical).He has replaced Pak a 2nd time.
Old Sep 24, 2015 | 11:57 AM
alloro's Avatar
alloro
Has the wiring to the tranny been inspected for little critter chew marks?
Old Sep 24, 2015 | 12:18 PM
Remmons's Avatar
Remmons
Trying to find a new harness. Not sure what is equivalent. Ford is no longer
making harness
Old Sep 24, 2015 | 12:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Nothing is equivalent. Ford doesn't sell harnesses. The normal method is to locate the problem and repair the issue.
Old Sep 24, 2015 | 07:10 PM
Remmons's Avatar
Remmons
I was trying to find which years might have same connections.From a junk yard or online. Thanks for the info.
Old Sep 24, 2015 | 08:47 PM
Mark Kovalsky
You'll need a harness from a 03 expedition 5.4 v8 4x4. Nothing else is going to be the same, though some others may be similar.
Old Sep 24, 2015 | 10:07 PM
Remmons's Avatar
Remmons
Hey Mark thanks,that is what I was thinking after spending a couple of hours looking at several junked expeditions.I do have another couple questions. I climb under it tonight after trying to clear code to no avail. After taking the wiring harness apart on passenter side of transmisson and spraying it with elect. contact cleaner and monkeying around with other 2 connecterst on driver's side. I was able to clear the code. Any suggestions? Thanks
Old Sep 24, 2015 | 10:19 PM
Remmons's Avatar
Remmons
Hey Mark drove it 50 miles. No lights on. Went to stop at stop sign od and check engine light came on. Drove the rest away to work.Let sit 2-3hrs. Started it up check engine on. Reset and no lights on. Could this be a transmission speed sensor issue?
Old Sep 25, 2015 | 01:19 PM
Mark Kovalsky
No, it cannot be a speed sensor. There is no way a speed.senor can set a solenoid code.
Old Sep 25, 2015 | 01:47 PM
Remmons's Avatar
Remmons
Just drove it about 4 miles fine first 2 miles pushed od in on shifter kicked in and out like it is supposed to do.Got off exit ramp and waited for light to change. Od started flashing both are on again.
Ericinkc
1997 - 2003 F150
May 27, 2016 01:03 AM
billoffley
Jan 19, 2010 08:01 PM
da0023
1997 - 2003 F150
Oct 11, 2009 10:33 AM
Leader
Mar 10, 2007 08:57 AM
