Sponsored by: Auxito
overdrive help
Old Oct 10, 2009 | 01:00 PM
da0023's Avatar
da0023
overdrive help
could anyone tell me why my o/d light keeps flashing and i am experience hard shifts when i slow down. i have a 99 f150 4x4 with the 5.4
Old Oct 10, 2009 | 01:24 PM
gtiguy's Avatar
gtiguy
the flashing means your tranny is f***ed
its just like the check engine light but just for your tranny
Old Oct 10, 2009 | 06:00 PM
redwood's Avatar
redwood
It doesn't necessarily mean that. You need to take it somewhere and have it hooked up to a scanner to find out what the transmission code is.............
Old Oct 10, 2009 | 07:09 PM
montanafordman's Avatar
montanafordman
If the fault code is serious enough it will cause the OD light to blink on and off. I had a spark plug misfire that got bad enough for the OD light to flash. I'd make sure that your check engine light is connected, or not burned out since the two typically go together.
<!-- / message --><!-- sig -->
Old Oct 11, 2009 | 10:33 AM
da0023's Avatar
da0023
thanks guys for all the responses. i will have the code read a.s.a.p. to see what is going on. thanks again.
