Was It Ok To Clean This? (with pics)
Was it ok to clean the upper control arm mounts? I'm thinking it was just old lube that I removed. I wanted to get rid of any grit before installing the new arm.
What should I use for lube on it? Silicone? The same as on the caliper slide pins?
Also, what is that vertical slot for?
Prior to cleaning (upper ctrl arm mount)
After cleaning (upper ctrl arm mount)
look at the control arm closely.... notice that the center bushing and mounting bolt are SOLID to the frame... they don't move or rotate.. The "arm" is allowed to move up and down when the rubber around the steel bushing "flex" and let the arm travel. You need no lube in the area... spray paint would be fine when all is clean.
Interesting. So the rubber bushings don't rotate? The arm moves on them but they only twist to some degree? I guess the notches are there to prevent the parts from rotating.
I wonder why it's like that. It seems like the bushings would wear out rather quickly by not rotating with the arm.
Treacy
04-11-2018 05:15 PM
Sbroom
10-16-2015 09:13 PM
Manwith3fords
09-19-2003 10:55 PM
