Need to replace some bushings...
Old Jun 19, 2009 | 05:10 PM
BAJI26's Avatar
BAJI26
Look at the picture:
Old Jun 19, 2009 | 07:48 PM
ReAX's Avatar
ReAX
That is a stamped lower control arm or Ford usually calls them radius arms because they don't use uppers. I would call it a radius arm bushing, but some manufactures may still call it a lower control arm bushing.
Old Jun 19, 2009 | 07:52 PM
Cardiac69's Avatar
Cardiac69
$7.83 each @ Rockauto.com for Spicer brand radius arm bushings....
Old Jun 19, 2009 | 08:52 PM
BAJI26's Avatar
BAJI26
Are they easy to change?
Is it a pair fro one arm?
Old Jun 19, 2009 | 09:15 PM
ReAX's Avatar
ReAX
The front should be a king pin, so it's just a bushing in each rear. If they are really loose, getting them out is simple. However a press will make it easy to put them in. I've never had the patients for using a BFH to drive rubber/poly bushings.
Old Jun 19, 2009 | 09:18 PM
BAJI26's Avatar
BAJI26
Where the red arrow is is that consider one radius arm bushings or is it two (one fro each side of that bolt)
Old Jun 19, 2009 | 10:48 PM
ReAX's Avatar
ReAX
It should be one, but I've not done it. The bushings I've seen like this are a primary sleeved bushing and a cap bushing for the other side.
Old Jun 21, 2009 | 10:18 AM
BAJI26's Avatar
BAJI26
Anyone who has change these can give me some direction!
Old Jun 22, 2009 | 08:21 AM
vettdvr's Avatar
vettdvr
Nothing will be easy. The steel sleeve will be difficult to remove, You really need a press. Due to the U shaped part it will have a tendency to bend. You will need a C type spacer to insure you don't bend the arm when pressing in and out the new bushing. I have done this on other vehicles not a Ex. but it can be done with a press. I would recommend you find a machine shop that will press in the part for you. Then you can remove the part and provide nessary repair parts and pay someone else to install it. Best of luck.
Old Jun 23, 2009 | 06:52 AM
BAJI26's Avatar
BAJI26
Thanks VET!
Anyone have actually changed it taht could give me steps and tools need? Thanks!
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
DaXman
Jul 3, 2015 05:38 PM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
