Power Steering Fluid - Which to Use
Old 09-21-2015, 07:55 PM
Etzcutter's Avatar
Etzcutter
Etzcutter is offline
Good Evening All
I am low on my power steering fluid on my 2005 Ford 6.0L diesel truck. The owner's manual says to use Motorcraft Mercon ATF.
I have:
- Mercon LV ATF
- Prestone Power Steering Fluid
I purchased several bottles of the Mercon LV ATF fluid for a future flush of the automatic transmission fluid. Should I use the Mercon LV ATF to top off my low power steering fluid? I just wanted to check to make sure I am reading the owner's manual right, the same oil for the automatic transmission and power steering fluid.
Old 09-21-2015, 08:20 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is online now
It is a little confusing.
The straight Mercon fluid is very similar to Dextron III and is what you want to use for the power steering hydro boost system, but not in the transmission.
The Mercon SP and LV are very similar and compatable with each other (along with Maxlife ATF) and either is suitable for the transmission but not the power steering system.
To be clear as mud Mercon is different from Mercon SP and LV fluids.
Old 09-21-2015, 09:33 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Get yourself a bottle of Mercon V to use to top up your power steering fluid.
Old 09-22-2015, 10:44 AM
Rick03F250's Avatar
Rick03F250
Rick03F250 is offline
Might as well get a gallon or so and do a flush, I've heard it helps both the steering and brakes.
Old 09-22-2015, 01:17 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Mercon V for the p/s.
Do a good flush, it'll make a difference in feel and noise.
Josh
Old 09-22-2015, 10:20 PM
joe blow's Avatar
joe blow
joe blow is offline
Confirmed!!!
Do yourself a favor and add a magnefine filter to aid in keeping it clean. HUGE improvement in brake feel.
Josh
Old 09-24-2015, 11:31 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Originally Posted by joe blow
Confirmed!!!
Interested in doing this, but on which line?
Old 09-24-2015, 12:25 PM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
Received 2,095 Likes on 1,420 Posts
When installed in the hydroboost return line it only cleans the fluid exhausted during a brake release. Putting in the steering box return line filters all the time. BUT if it gets clogged there is the danger of the unit rupturing. While Ford did in a TSB talk about putting one in the box return line to remove debris, they also stated to remove it afterwards. There were some of us with the 7.3L that put them in for a long time without issue.
Old 10-04-2015, 03:10 PM
wgcdc's Avatar
wgcdc
wgcdc is offline
Josh
I saw this post a few weeks ago and I didn't want to hijack the OP's thread. However, it appears that I may have messed up. I flushed my P/S with Mercon LV about 10,000 miles ago. If I read this correctly it should have been Mercon V. What sort of trouble have I made for myself and how should I correct it?
Old 10-05-2015, 09:23 PM
Bullitt390's Avatar
Bullitt390
I doubt you have caused any issues. And you certainly would have heard the p/s pump start whining by that time. Mercon SP is likely too thin for the steering and booster, but LV isn't that much thinner than Mercon V.
I wouldn't lose sleep over it myself. Maybe flush it all out at the 30K mark with Mercon V.
Josh
Old 10-05-2015, 09:33 PM
wgcdc's Avatar
wgcdc
wgcdc is offline
Good news. Thank you sir!
Jesser02EX
11-14-2013 10:24 PM
mlelah
10-01-2011 05:48 PM
xplorerboy
12-06-2009 07:48 PM
eprn1n2
02-15-2009 12:51 AM
kntryboy
1997 - 2003 F150
11-27-2005 06:07 PM
Quick Reply: Power Steering Fluid - Which to Use
