Power Steering
Old Feb 14, 2009 | 06:49 PM
eprn1n2's Avatar
eprn1n2
Power Steering
What fluid is used in the power steering pump? I read it is ATF but is there a certain type?
Old Feb 14, 2009 | 07:05 PM
MIKE1646's Avatar
MIKE1646
I put the same as the transmission Mercon SP
Old Feb 14, 2009 | 07:21 PM
eprn1n2's Avatar
eprn1n2
Thanks. I've looked everywhere but just could not not find any info.
Old Feb 14, 2009 | 10:09 PM
bismic's Avatar
bismic
I really would NOT mix Mercon V and Mercon SP. I am fairly certain that the power steering fluid is the same as the tranny fluid in manual transmissions. That means it is Mercon V. Mixing the two in transmissions is certainly bad - I am assuming it is a no-no in the PS fluid as well.
Here is a summary of fluids and filters for the 6.0L:
http://www.midwaytruck.com/Ford%20Pr...rts%20List.pdf
Old Feb 14, 2009 | 10:26 PM
eprn1n2's Avatar
eprn1n2
Without a way to determine the present fluid a complete flush would be needed. Also your spread sheet guide is very useful. thanks
Old Feb 15, 2009 | 12:51 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
My manual states Mercon... but we all know that it was discontinued and Ford now states you can use Mercon V.
