I hope it's nothing...
Old Sep 16, 2015 | 04:17 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
... But my gut tells me otherwise. Monday while here in PA. my truck started makeing a clunking sound when I put it in gear and sometimes when I let off the throttle going 50-60mph. Also when I let off at that speed I'm getting more driveline vibrations that wern't there before. The banging-clunking sound sounds like it's right below my feet. U-joints are good as well as the carrier bearing. Haven't greased the slip yoke in awhile maybe that's it I wonder. Transmission shifts great, other than that sound putting in gear. Any help would be welcome....Bill
Old Sep 16, 2015 | 04:27 PM
HKusp's Avatar
HKusp
Grease that slip yoke. That is classic description of what it does when it is dry.
Old Sep 16, 2015 | 05:20 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Jason, would that make it sound like it's right below my feet?
Old Sep 16, 2015 | 05:31 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I haven't greased the slip joint in years. Seal has been gone forever too. The splines are basically dry all the time. I would be surprised if thats it.
When you say the u-joints are good you mean....???
Old Sep 16, 2015 | 05:35 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
No detectable play.
Old Sep 16, 2015 | 06:59 PM
Thomas White's Avatar
Thomas White
Originally Posted by DISLFVR
No detectable play.
Be sure when you check these, the vehicle is neutral and the parking brake if off. CHOCK WHEELS FRONT AND BACK !!!!!!!!!!!!!!!
This way there is no stress on the drive train and you're more likely to identify a worn one. But.....
Old Sep 16, 2015 | 07:07 PM
F350-6's Avatar
F350-6
My clunk was U joints. That's what I would have guessed.
Old Sep 16, 2015 | 07:42 PM
Nader's Avatar
Nader
I had a clunk on take off a few weeks back. Went away when the slip yoke was lubed and re-sealed.
Old Sep 16, 2015 | 10:11 PM
cookie88's Avatar
cookie88
FTE Emeritus
No detectable play.
Replaced mine a couple weeks ago. No play so I thought they weren't the problem. They were.
Old Sep 17, 2015 | 04:55 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I'll ckeck them again, before we leave this morning..
Old Sep 17, 2015 | 06:06 AM
Tugly's Avatar
Tugly
When I installed my ladder bars, I was shocked at how much jolt was gone with the shifts. My wife immediately noticed it as well. Just another angle to look at.
Old Sep 17, 2015 | 10:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you are checking joints with the drive shaft installed you won't find many bad ones. Take it out.
Old Sep 17, 2015 | 04:27 PM
Bonanza35's Avatar
Bonanza35
Let us know what you find. I had the clunk after JW serviced my trans and replaced my carrier bearing. Never had it before.
Old Sep 17, 2015 | 05:09 PM
Nader's Avatar
Nader
Interesting, because I also had that new clunk after the transmission was replaced with the HD unit (the first time). I was told it was the slip yoke, it was addressed, and the noise is gone. Then again, I don't have the greatest confidence in the dealership that has been addressing my issues.
Old Sep 17, 2015 | 08:08 PM
97-psd's Avatar
97-psd
I would grease the slip yoke first and see if that solves the problem. If not, then pull the drive shaft and check the joints. Checking them in the truck doesn't give a true representation of their condition.
