Where can I get a new radiator for my stock truck? Most places I have looked are for street rod applications. I am still running a flat head engine. Might try aluminum, mine has a couple of holes in it and by the time I take it in and get it cleaned and fixed, I just might as well get a new one, any help would be great. thanks Gary
I had mine recored (4-row) 12 years ago, before copper went crazy. It was about $150... But nothing compares to copper. It's repairable, it cools best. Many of the cheaper aluminum radiators can't be rodded out, have glued-on tanks, etc. Truly a case of getting what you pay for.
I find a lot of stuff on Craigslist.
I bought a spare F1 radiator today that was once recored, and it came with a shroud for $30. It will need to be roded and cleaned.
I must say it is noticeably lighter than the original Ford radiator I have. Locally it cost about $175 to rod and clean.
All this to say go with a copper core, and if you can save your original I think it is a good investment.
Your radiator guy should be able to assess the deterioration, leaks are not an issue unless the core is rotten.
A local shop who builds radiators:
The Brassworks
thebrassworks.net
49-53 flathead 4 row core radiator. $949.00
C&C Early Ford Parts, Escondido, Ca : 7RT-7009A. $609.00
and a little closer to you VanPelt Sales : http://www.vanpeltsales.com
None listed but he should have a lead for you. Mac the owner will answer, great business.
More rows of tubes create more cooling area. Pictured is a 4 row core. Plenty of cooling for our F1, my rebuilt engine cools very well and I haven't installed the shroud yet.
