Inside ceiling bulbs
Old Sep 15, 2015 | 07:16 AM
finlander's Avatar
finlander
Want to change bulbs in ceiling. The bulbs for the two clear lens push in lights. I have a 2004 f150 supercab. The storage area behind this panel I have removed. Do you pry the forward panel off? What's the trick? Thanks.
Old Sep 15, 2015 | 07:18 AM
projectSHO89's Avatar
projectSHO89
Have you checked your owner's manual for instructions?
Old Sep 15, 2015 | 08:55 AM
finlander's Avatar
finlander
Not one hint as to remove this forward
cover that houses those two courtesy
bulbs
Old Sep 15, 2015 | 11:51 AM
projectSHO89
Those are called the "Map lights".
It's odd that neither the owner's manual or the shop manual has instructions. They must have assumed it wasn't too difficult if they didn't include anything for the technicians...
Old Sep 15, 2015 | 12:07 PM
projectSHO89
Check this video and see if it helps. Skip forward to :55 seconds and see if the shown map light unit is the same. If so, just watch the video.
Old Sep 15, 2015 | 01:21 PM
finlander's Avatar
finlander
Lights
Used a screw driver to pry off cover
There are four tabs holding it in place.
Luckily none popped off. New bulbs in
place. Thanks for all the quick replies!😄
abe
Dec 30, 2015 09:26 PM
mtl93ranger
1983 - 2012 Ranger & B-Series
Dec 26, 2007 02:04 PM
2000_gator_2000
Jan 1, 2007 03:25 PM
ChinPokoMon
Feb 22, 2004 03:29 PM
fordtruck99
Electrical Systems/Wiring
Feb 20, 2003 01:07 PM
