Spare parts
Old Sep 7, 2015 | 09:11 PM
KDAVID1's Avatar
KDAVID1
Spare parts
Doing some cleaning and putting tools back in place before I do my front end and have a few are parts if anyone gets in a bind.
Upgraded turbo feed (I think I have 2)--8crewdually
Oil filter drain valve (took it off of the damaged filter adapter)-to Yahiko
Oil filter cap oring
Oil cooler outlet gasket (the one that looks like a j)
Turbo feed line gasket and oring--to mudfuel06
Intake bolt (one with stud top)
I may have a few more goodies but these are the ones I've found so far.
I can get part numbers off the packages where possible. All of these are new except the oil filter drain valve and one of the turbo feed lines.
Old Sep 7, 2015 | 09:29 PM
Yahiko's Avatar
Yahiko
Not in any bind at the moment.
But I do have an extra oil cooler assembly that the top adaptor
is missing the oil drain valve. How much would like for that little
doodad?
Sean
6.0L Tech Folder
Old Sep 8, 2015 | 04:55 AM
GenMan's Avatar
GenMan
I'm in need of a bottom starter bolt or if someone knows the size I'll pick one up.
Old Sep 8, 2015 | 08:48 AM
mudfuel06's Avatar
mudfuel06
Turbo feed line gasket and oring How much for this one?
Old Sep 8, 2015 | 08:50 AM
KDAVID1's Avatar
KDAVID1
yall send me a PM and with your addresses and I'll put the stuff in the mail.
no charge--yall have helped me so time to give back.
KDAVID1's Avatar
KDAVID1
That one I sure don't have.
Old Sep 8, 2015 | 07:36 PM
KDAVID1's Avatar
KDAVID1
Don't forget to pm me
Old Sep 9, 2015 | 11:53 PM
Yahiko's Avatar
Yahiko
Sorry for the little
I sent you an Email but just in case it goes missing.
The bolt is 12 mm X 50 mm X 1.5 thread.
Check to see if the threads are striped out of the starter ear.
If you find that they are like I did. Here is what I did.
Longer bolt that stuck far enough out to put a nut on.
Then use a nylock ,some type of locking nut or blue Loctite.
Sean
6.0L Tech Folder
Old Sep 10, 2015 | 04:39 AM
GenMan's Avatar
GenMan
Thanks!. When i put the CAT test pipe on I noticed it was gone. I'll get one today.
klle5
Mar 23, 2016 04:52 PM
BryanStein
Aug 30, 2014 07:39 AM
JonArmy
Mar 5, 2012 07:23 PM
levimorris85
Jun 8, 2011 08:13 AM
KyleG
Feb 14, 2008 11:14 AM
