oil leak
Old Jun 6, 2011 | 08:51 PM
levimorris85's Avatar
levimorris85
oil leak
Ok guys, I need some help. The wife has an 03 Excursion 6.0 with 90k. There is oil leaking all over the drive. I took it to the local ford dealer to find the leak and they said it a gasket up buy the oil filter. I asked a couple of times and they didn't know the actual part name . Does anyone know what gasket they could be talking about. I would like to save the 250.00 they want to fix it by doing it myself, just need to know what the heck the part is. Thanks for the help.
Old Jun 6, 2011 | 09:04 PM
BLADE35's Avatar
BLADE35
theres a oil cap gasket and another one at the filter base and a oil cooler/oil filter gaskets and a turbo oil feed all righ there hope its not one of the lower oil cooler ones
wheres the oil coming out at can you tell
could be the one at the filter base probably not to deep if they only wanted 250.00
Old Jun 6, 2011 | 09:10 PM
levimorris85
I cant tell where its coming from. I have been all over, under, inside and out and cant find it. I will go see if I cant get them to give me the name of the part (maybe it will be a different service tech). I was just hoping that someone had been down this road before. Thanks again and keep the ideas rolling.
Old Jun 6, 2011 | 09:39 PM
BLADE35's Avatar
BLADE35
lots of us been down this road well at least been into the oil cooler theres just alot of gaskets right there is the problem
get a flashlight and try and pinpoint where its coming from clean it off if you can blow it with compressed air and watch it while it idels
look at the one at the base of the round oil filter and at the oil line that goes to turbo look at the bottom of the turbo oil line
theres only a few you can get without majoir work Ill try and find a pic
Old Jun 7, 2011 | 07:53 AM
levimorris85
Thanks Benny. I called the Ford dealer this morning and talked to someone that actually helped me. They claim that the tech notes state that its the oil regulator gasket leaking. Has anyone changed these out, if so how big of a job is it? thanks again.
Old Jun 7, 2011 | 07:15 PM
BLADE35's Avatar
BLADE35
ok I found some pics
oil filter base
Page 25: Lubrication System
IPR
Page 42: Fuel Management System
this is the IPR injector pressure regulator {high pressure oil]
IPR$ICP pics
Page 11: Component Locations
oil cooler this ones under the oil filter
Page 24: Lubrication System
ICP and IPR can be tuff what year truck do you have
Is it coming off the back of the moter
Old Jun 7, 2011 | 07:21 PM
wulfman's Avatar
wulfman
I have never heard of a oil regulator .
Old Jun 7, 2011 | 07:28 PM
BLADE35's Avatar
BLADE35
I figured he ment the IPR
Isnt there a oil pressure regulator in the front cover
Old Jun 7, 2011 | 07:29 PM
wulfman's Avatar
wulfman
I found a oil press regulator located on front cover, seem it would be leaking up though. Has the oil been changed lately if so could be oil filter cap o ring , don't ask how i know, but can leak bad or just a little, something to check
Old Jun 7, 2011 | 07:42 PM
BLADE35's Avatar
BLADE35
have you narrowed down the location of the leak [top of moter to back of moter or front moter]
I was thinking that gasket to david or the lower one same location pic in first link
Old Jun 7, 2011 | 07:56 PM
cheezit's Avatar
cheezit
remove the connector on the oil pressure swich and see if its full of oil. thast the most common thing in that area.
Old Jun 8, 2011 | 08:13 AM
levimorris85
I will try to answer all the question and thanks again for all the help. Yes the oil is running off the back of the motor. There is no oil on the front. I cant tell where but it looks like somewhere around the oil filter. I Have never hear of a oil pressure regulator either. that just what the blue oval shop told me. I changed the oil about 3k ago and it was even leaking before then. I loose maybe a 1/4 of a quart of oil ever 4k. it is just making mess all over the drive and where i park at work. Thanks again for ALL the help FTE has been.
smallello
Jul 12, 2014 07:50 PM
Stealth94rttt
May 1, 2013 04:24 PM
oldfueler
Apr 30, 2012 12:35 PM
orange_x_crush
Sep 6, 2008 04:00 PM
fordguy76
Oct 16, 2002 12:14 AM
