shudder in reverse 4R100
Old Sep 7, 2015 | 01:19 PM
donmi's Avatar
donmi
Hi Guys,
a few days ago, I was trying to back up with my 5th wheel (12,000lbs) and in reverse the transmission was shuddering combined with a noise.
So I stopped and since than, the reverse is shuddering when I accelerate
If I put it in reverse and let it in idle, everything is fine.
The forward gears without problem.
Temperature always between 140 and 160, never overheated.
F350 Dually Crew cab, 7.3, 1999, 215,000 km, superchip,
never overdone it with the power.
Fluid level ok, no burned smell at the fluid, still red in color.
Any ideas?????
Thanks
Michael
Old Nov 1, 2015 | 02:18 PM
collazoscesar's Avatar
collazoscesar
reverse shudder
Hello, My truck is doing the same thing, did you ever find out what the problem was.
Thanks
Cesar
Old Nov 1, 2015 | 04:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is possible that it is a driveshaft alignment issue, but it is more likely to be a damaged low/reverse clutch, or even the direct clutch.
Old Nov 2, 2015 | 08:44 PM
donmi's Avatar
donmi
Yes, it was the reverse clutch.
Got the transmission rebuild with a triple clutch Torque Converter and heavy duty shift kit.
Now I have a noise, coming obviously from the flexplate, will get a new one.
Wild-Bill
Dec 12, 2013 05:56 AM
tdawglp
16
Apr 29, 2012 09:07 AM
tbart16
Feb 1, 2010 11:31 AM
60RatRod
Dec 19, 2008 08:44 AM
Country705
Feb 11, 2007 08:45 AM
