Bouncing tach?
Old Sep 8, 2015 | 03:30 PM
Mitchapalooza's Avatar
Mitchapalooza
Sorry I misunderstood what you meant earlier, I was talking about the Starter relay not the ignition module on the fender
Old Sep 8, 2015 | 06:18 PM
Mitchapalooza
So I swapped out the ignition module... Yea same BS. I can think of anything else ignition wise that would cause this issue smh. This is getting ridiculous
Old Sep 8, 2015 | 06:26 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Quick link. I'm on mobile.
http://www.autozone.com/repairguides...00c1528008faaa
Old Sep 8, 2015 | 06:29 PM
Archion's Avatar
Archion
Originally Posted by Archion
And you are getting battery voltage at the main lead into the dizzy, right?
Old Sep 8, 2015 | 07:04 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
2000 miles? ?!?
I'd be changing that stupid HEI every month or two.
Old Sep 8, 2015 | 07:11 PM
Mitchapalooza
Link won't come up on my iPhone just goes to autozone home page.
I would assume so but I would have to check tomorrow if I have time after work
Old Sep 8, 2015 | 07:15 PM
Archion's Avatar
Archion
Click view full site and the bottom and then visit the link again.
Old Sep 8, 2015 | 07:21 PM
ctubutis's Avatar
ctubutis
I fixed the links on the desktop site; that can happen when posting from mobile devices...
Old Sep 10, 2015 | 08:20 AM
Mitchapalooza
Link above is a small video on how the truck idles from a cold start. I'm applying no throttle just letting truck idle to normal temp which is when it starts to act up. I am aware of the small ticking sound (exhaust leak) lol You can fast fwd to 3:15 when it starts acting up
Old Sep 10, 2015 | 08:36 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You are getting battery voltage at the main lead into the dizzy, right?
This
Most any "all in one" dizzys will call for HEAVY wire relayed directly to the unit. (Skip White says 10Ga.)
There's no way the stock harness is going to supply this.
Old Sep 10, 2015 | 09:22 AM
Mitchapalooza
Well this being my 1st carb vehicle I'm still learning the ropes on tweeting with a distributor, so you're saying I need a larger gauge power supply to the distributor?
Old Sep 10, 2015 | 09:31 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Did you read the install instructions that came with the distributor?
I'm only familiar with the DUI and Skip White.
Both say you need a 30A fused connection in run & start.
Old Sep 10, 2015 | 10:16 AM
  #28
Franklin2's Avatar
Franklin2
You did use lots of white heatsink grease on the module correct?
Old Sep 10, 2015 | 01:25 PM
  #29
Mitchapalooza
Yes I did franklin2
Old Sep 19, 2015 | 09:51 PM
  #30
Mitchapalooza
Update: After some extra troubleshooting found out that the actual Distributor shaft that is turned by the gear was seized up. I actually had to get a rag & hand turn the gear. I honestly don't know how the truck even turned on with this issue. Installed new Proform Distributor & turned right over no issues.
mustang_gt_350
Aug 31, 2015 07:47 PM
Knightwarp
1978 - 1996 Big Bronco
Feb 13, 2007 01:10 PM
MustangGT221
Jun 27, 2004 08:04 PM
skelator
20
May 18, 2004 05:28 PM
shotty
Aug 4, 2003 06:11 PM
