1978 - 1996 Big Bronco
RPM fluttering
Old Feb 9, 2007 | 04:33 AM
Knightwarp's Avatar
Knightwarp
RPM fluttering
My Tach is fluttering and I cannot figure out what would cause this? I replaced the pickup coil and the module and I keep the plugs, wires and distributor with rotor replaced every 6 months. I use top of the ;line products and I still have not figured out what is causing my Tach to flutter. Would the flittering problem also cause stalling?
Thanks for any help
knightwarp@lycos.com
Old Feb 9, 2007 | 10:10 AM
Kemicalburns's Avatar
Kemicalburns
pull codes www.fordfuelinjection.com
Old Feb 10, 2007 | 05:49 AM
Knightwarp's Avatar
Knightwarp
Talking
I found that problem thanks to all who helped. It was my coil. Even though it looked good I was replacing the fuel pressure regulator when I bumped the coil and it wiggled. I replaced it with a new one. Tach no longer flutters. Whenever I hit bumps the coil would move causing the tach to jump.
Old Feb 13, 2007 | 01:10 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Coil
Because the negative coil is wired directly to the tach, is why you experienced the fluctuation. By the way, sometimes a defective tach can short out an ignition coil.
http://www.performancedistributors.c...50ignition.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
