Radius arms
Old Sep 1, 2015 | 07:09 PM
ssandirene's Avatar
ssandirene
Radius arms
good evening,
I'm going to put the front suspension from a 1975 f150 under our 65 f100.
I have everything but the radius arms, will the ones off the 65 work?
It's a two wheel drive
Thanks
Old Sep 2, 2015 | 11:39 AM
daveengelson's Avatar
daveengelson
Suggest call couple auto part supplier's and see what their catalog indicates. Replaced mine many years ago with the front disc. upgrade and seem to recall replacing with 66 radius arm bushing. Approx.a month ago replaced the radius arm bushings and had similar discussion with 2-3 auto part supplier's. I took the original bushing for comparison and after several miles each came up with the same bushings whether I asked for 66, or 75 bushings.
Suggest thoroughly inspect the current bushings for wear, as you are probly well aware, replacing can be labor intensive and you do not want to have to replace sooner than necessary. If the front and rear washers and nut are okay, don't want to go back for redo considering the bushing should not cost more than $15? Also, make sure to follow the torque spec's, important when it comes to alignment. Anyhow, food for thought?
Old Sep 2, 2015 | 01:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The front (C5TZ-3B203-C) & rear (C5TZ-3B203-B) radius arm insulators (bushings) are the same: 1965/75 F100/250 & 1967/75 F350. Also same as 1969/74 E100/300 & 1975/79 E100/350.
Pic: Scroll down to 3B203 bushing applications for 1973/75 F100/350 & Econoline from 1973/79 truck catalog.
Old Sep 2, 2015 | 02:23 PM
resonateur's Avatar
resonateur
I believe he's referring to the radius arms, not the bushings.
Old Sep 2, 2015 | 02:30 PM
NumberDummy
Read Dave's first paragraph inre to bushings.
Old Sep 2, 2015 | 05:40 PM
resonateur's Avatar
resonateur
yup...I meant that ssandirene's initial query was whether the 65 radius arms could be used with the 75 suspension. I'm curious as well.
Old Sep 2, 2015 | 05:57 PM
daveengelson
Sorry, yet again miss read the questions 'whether the 66 radius arm will work with the 75 application', I did use the original 65 radius arms when I upgraded to the 75 front disc brakes. Sorry, perhaps my comments will help should it come down in deciding on radius arm bushings?
Old Sep 2, 2015 | 06:11 PM
ssandirene's Avatar
ssandirene
Thank you for the replies,
I wanted to know if the arm itself would interchange.
Russ
Boba Fett
Jul 7, 2014 08:36 AM
flying4fish
Apr 26, 2009 01:53 PM
bliss1
Nov 25, 2007 06:29 PM
OffRoadF-150
Offroad & 4x4
Jan 4, 2006 01:32 PM
ExcellentRed
Mar 1, 2004 09:06 PM
