65 radius arm bushings
Old Nov 24, 2007 | 10:42 PM
bliss1's Avatar
bliss1
im doing my radius arm bushings and the bushings ive got are a lot thicker than the ones that are on the truck. iwent to put them on and cant get the castle nut even close to the hole. every web site have the same part listed for this truck, they dont look like the origanal part. any help would be great.
Old Nov 25, 2007 | 06:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/74 Radius Arm Bushings
1965/74 F100/350 radius arm bushings are the same.
C5TZ-3B203-D = Rear / C5TZ-3B203-E = Front
_______________________________
1975/79 F100/350 radius arm bushings are DIFFERENT!
1975/79 F100/350 bushings are THICKER than the type above.
D5TZ-3B203-C = Front / D5TZ-3B203-D = Rear
Old Nov 25, 2007 | 11:32 AM
bliss1's Avatar
bliss1
i think the problem is that the parts store just threw them all under one group, because they list the same part for the 79 f100. the problem is trying to tighten down enough to get to the hole for the castle nut. 79 it does not use a castle nut and has a longer threaded area.
Old Nov 25, 2007 | 11:48 AM
rogue40's Avatar
rogue40
I had the same problem. I lubed it all up with vegetable oil and pressed it together with a "C" clamp. When I pulled the clamp it stayed together enough to get the castle nut started.
Just make sure everything goes together straight.
Old Nov 25, 2007 | 11:55 AM
rogue40's Avatar
rogue40
Sorry, I just went back and reread your last post.
To answer your last question; RATTLE GUN!
Old Nov 25, 2007 | 02:37 PM
bliss1's Avatar
bliss1
i went and found some OEM bushings, went together great with the right part.
Old Nov 25, 2007 | 05:15 PM
NumberDummy
I forgot to mention that both of these types are still available from Ford.
Old Nov 25, 2007 | 06:29 PM
bliss1's Avatar
bliss1
well i know were to look for them next time. iwent and called about 10 diffrent part stores to find the ones ive got. thanks for the input you guys.
86fn150
Sep 7, 2015 01:58 PM
LITTLE BLACK TRUCK
27
Aug 13, 2015 02:30 PM
daveengelson
Jun 15, 2015 05:06 PM
Boba Fett
Jul 7, 2014 08:36 AM
codyingersoll123
32
Feb 28, 2009 05:31 PM
