BATTERY DRAIN V2
Old Sep 1, 2015 | 06:58 PM
84&04's Avatar
84&04
BATTERY DRAIN V2
Last 4-6 days no problems. Out of the blue dead again... Nothing was left on...
4th alt
4th voltage regulator
2nd set of batteries
What in the ****... Starting to wear on me... Been down every test and guess with everyone who commented last time. Seemed resolved. But looks like I was wrong.
Old Sep 1, 2015 | 10:54 PM
Macrobb's Avatar
Macrobb
It's probably something stupid like a glovebox light that's staying on or something.
Just hook up an override solenoid between the battery accessory wire and everything else:
http://www.ebay.com/itm/NEW-SOLENOID-GOLF-CART-MARINE-WINCH-12-Volt-Continuous-HEAVY-DUTY-/360407366651?hash=item53e9f3fbfb&vxp=mtrPower it with a switch on the dash. Instant solution, and then you can fix the other problem at your leisure.
Old Sep 1, 2015 | 10:58 PM
84&04's Avatar
84&04
That's pretty much what I was considering hahaah!!!! But I'm just losing my mind, alt was warm this morning -_- granted it was almost 100, but the alt almost cooked my hand. I'm debating unplugging my voltage regulator and letting it sit next weekend see if it happens again... It's just becoming irritation... And my local parts place is becoming quite annoyed...
No power in cab aside from cluster lights and power window fuse... Tested them both, neither of them are my issue,,, I've got a constant draw somewhere, and I'm thinking it's the alt..
Old Sep 1, 2015 | 11:16 PM
Macrobb's Avatar
Macrobb
Oh. I'll bet you the "I" wire on the regulator is mis-wired.
Make sure it doesn't have power with the key off, and it should be fed through a light bulb(usually the dash light).
If it's fed straight from power, the alt will get hot and eventually fry. Even fed through a light bulb(which limits the amount of power it can draw), it should still be switched power.
Old Sep 1, 2015 | 11:19 PM
84&04's Avatar
84&04
Originally Posted by Macrobb
Oh. I'll bet you the "I" wire on the regulator is mis-wired. Make sure it doesn't have power with the key off, and it should be fed through a light bulb(usually the dash light). If it's fed straight from power, the alt will get hot and eventually fry. Even fed through a light bulb(which limits the amount of power it can draw), it should still be switched power.
So since my IP is on an seperate switch. Can I wire the "i" wire to that, so it's only on when the trucks on?
Old Sep 1, 2015 | 11:24 PM
Macrobb's Avatar
Macrobb
Probably - It shouldn't backfeed power into the FSS solenoid through that wire.
Wire it through a light bulb, though(either an indicator light or tail light).
With the engine off and key/power on, the light should be on. Once the engine is running, the light should go out or be really really dim(if it doesn't, it means you aren't charging).
Old Sep 1, 2015 | 11:26 PM
84&04's Avatar
84&04
So, just so we're on the same page, the pervious owner cut everything up lol. Ran his own "wiring" if you could call it that... But it's charging... Just apparently draining...
Old Sep 2, 2015 | 08:03 PM
Macrobb's Avatar
Macrobb
Yes. So you will need to run your own custom wiring, or figure out the stubs of factory wiring.
If you can find whichever wire went to the dash light, great. If not, use a light bulb and find switched power.
Old Sep 2, 2015 | 08:04 PM
84&04's Avatar
84&04
Alright! Thanks for the help! Looks like I'm going to tie the "I" to the fender marker! Thanks a million! I'll repost if it doesn't work....
Old Sep 2, 2015 | 08:11 PM
Macrobb's Avatar
Macrobb
Just remember you need to tie it to one side of the light, and the other side goes to power not ground.
Old Sep 2, 2015 | 08:12 PM
84&04's Avatar
84&04
Perfect! Hahaha my fender is munched there ahahah
mchandford71360
18
Jan 8, 2019 09:13 AM
whitleycj
Dec 29, 2010 03:34 PM
7283-F250
Electrical Systems/Wiring
Nov 11, 2008 08:53 AM
erawtik
23
Oct 16, 2004 04:33 PM
tburk141
May 16, 2004 01:43 PM
