Charging Troubles?!?!??!?
Old May 15, 2004 | 10:56 AM
tburk141's Avatar
tburk141
Hey all,
I've been rackin' my brain trying to figure out where the short is that's causing a constant drain on the battery of my '80 F-150. When I start the truck the voltage reads about 11.5 volts across the posts. The battery is good. It has a recent voltage regulator and alternator. I started out by pulling off the negative battery clamp and connecting my test light from the negative clamp to the negative post. With the key off the light comes indicating a short. I pulled every fuse out of the panel one by one to try and at least narrow it down to a circuit, but the light never went out. Could the short be on an unprotected circuit?
If anyone else has experienced similar troubles I would appreciate your insight....
Trevor
Old May 15, 2004 | 02:34 PM
shaggymane's Avatar
shaggymane
11.5 volts on a running truck is just way to low. A standing battery ought to have 12.8 and running 14.3 or 14.5. First thing I'd do is clean the battery posts and make sure the belt is tight. Dirty connetions won't allow charging.
Regardless of the regulator being "recent", i'd strongly suspect it for both the low voltage and drain.
Keep in mind that the autoparts stores do lot of different testing now. check it out.
As far as the drain - Does the test light dim under any circumstances? I don't think you have main power distribution box (can't recall seeing one on my 82) like my 91 Expy has, so you don't have a "main fuse". With your test light in place like you were doing, start ungrounding things that have "always hot" wires, like the V reg and the selenoid etc etc............... cigarette lighter. Any lights stuck in on position?
As always, key off, door closed and underhood bulb removed if you have one
PS Could the short be on an unprotected circuit? yes
Old May 16, 2004 | 08:26 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
You may want to disconnect the wire to the under hood light if you have the retractable cord one. I rebuilt mine and the inside is not so great. It is possible that the wires inside can break and short there. Of course, if that were the case the light wouldn't come on.
Old May 16, 2004 | 01:43 PM
tburk141's Avatar
tburk141
Thanks again for the replies guys... I finally nailed the problem last evening. Turned out to be a faulty voltage regulator, $16 later and I'm back in business....
Trevor
Heather88
18
Mar 27, 2014 06:35 AM
old broke prospector
Apr 9, 2013 07:43 AM
mugglemac
1983 - 2012 Ranger & B-Series
Mar 31, 2011 04:07 PM
g_k50
1978 - 1996 Big Bronco
21
Oct 11, 2008 07:48 PM
Bowins
Electrical Systems/Wiring
Aug 10, 2005 08:03 AM
