No start plz anyone help
Old Aug 31, 2015 | 12:32 AM
Caroline Roy's Avatar
Caroline Roy
I got a 2003 f 350 with the famous 6.0 powerstroke diesel last week it started acting up wouldnt start when it was hot had to let it sit a few hours then it would fire right up seeing its my only transportation i decided to keep driving it just not to shut it off unless i planned on staying somewhere for a while so the last time i went somewhere i stayed a few hours when i left it fired right up got about 500 feet diwn the road it stalled and needless to say now im on foot will not start at all cranks fine just no start any help would be great im new to this diesel stuff thanks in advance Jerry
Old Aug 31, 2015 | 01:15 AM
Yahiko's Avatar
Yahiko
First off Welcome to FTE.
03 so you don't have stand pipes and dummy plugs to deal with like later years.
Do you have any way to read live data? Also did you know if any codes
are set and what they are?
Have a look in the Tech Folder at the top of the forum. Look at the
no start and hot no start stuff to start with.
Have you had any work done lately? Battery, charging system and FICM condition
are always things to know how they are doing.
We are going to need the live data info to get a good idea about what may be going on.
I don't like shooting in the dark it only costs money.
Sean
6.0L Tech Folder
Old Aug 31, 2015 | 09:00 AM
Caroline Roy
Are u sure i dont have standpipes ive been looking on the net and they sell thrm for a 2003 and what do i need to check readings the only work done lately is altenator and oil change
Old Aug 31, 2015 | 09:20 AM
Money-Pit's Avatar
Money-Pit
Here's some great info on the different OBD monitors for our trucks that Rusty put together.
https://www.ford-trucks.com/forums/1...eral-info.html
Also, list your location...one of us maybe be local and could help.
Old Aug 31, 2015 | 10:12 AM
Caroline Roy
. Im in coaticook quebec
Old Aug 31, 2015 | 10:13 AM
Caroline Roy
Old Aug 31, 2015 | 01:43 PM
Yahiko's Avatar
Yahiko
Well let me clarify this a bit.
You do have stand pipes BUT not they type that are problematic.
Your year tends to have problems with the HPOP pump.
HPOP is High Pressure Oil Pump
For diagnosis you need to see live data. Things like ICP and IPR
IPR is Injection Pressure Regulator Minimum 500 PSI to start
ICP is Injection Control Pressure Given in %
I do have one thing for you to try. Reach under the turbo from the back side and
unplug the ICP electrical connector. (not the IPR) and see if it will start.
What this does is it puts the PCM in a default pressure mode and it may start.
Read this one on the ICP No Start issues >> https://www.ford-trucks.com/forums/8...with-6-0l.html
Here is some good info to read >> https://www.ford-trucks.com/forums/7...ew-owners.html
This thread has a good NO Start check list >> https://www.ford-trucks.com/forums/8...condition.html
Be sure to thank Bismic for the help
This is a link to the Tech Folder at the top of the Forum >> https://www.ford-trucks.com/forums/3...ch-folder.html
Sean
6.0L Tech Folder
Old Aug 31, 2015 | 03:17 PM
ithaca1230's Avatar
ithaca1230
had a similar problem recently code showed up Cam shaft position sensor. Replaced it all is well now
Old Aug 31, 2015 | 03:57 PM
Caroline Roy
A buddy came over with his snap on reader here is what i got ficm low- 13 ficmm-47.5 Icp dsd-15828. Icp pressure-0. Icp v-0.09 has one code p0603 didnt see any place to check ipr
Old Aug 31, 2015 | 04:22 PM
WatsonR's Avatar
WatsonR
FICM 13, input good
FICM 47.5 output good
ICP=0 key off good
ICP votage .09 is bad if that was trying to crank the motor. If that was key off, it's fine.
We need ICP while cranking, should be more than 500psi and voltage should be higher or equal to .9 or around that number, not .09
P0603 is KAM memory, probably from disconnecting the battery, no worries.
What is this>>> Icp dsd-15828?
Old Aug 31, 2015 | 05:27 PM
Caroline Roy
The icp pressure that was while it was cranking would that cause it to stall on the road?
Old Aug 31, 2015 | 06:03 PM
69cj's Avatar
69cj
ICP needs to see 500 psi min. to run. Did you try unplugging the connector? Is the connector or ICP oil soaked? Easy and imp. steps to try.
Old Aug 31, 2015 | 06:06 PM
Caroline Roy
Ok and if its not the pushing 500psi ? Is it the sensor or
Old Aug 31, 2015 | 06:30 PM
evan1242's Avatar
evan1242
if it does not act normal with the sensor unplugged then you have an HPO leak. (high pressure oil)
an air test should be next on your list.
with yours being an 03, the HPOP is most likely the culprit, but only an air test will tell you for sure.
(high pressure oil pump)
there are some youtube videos of how to do it.
Old Sep 2, 2015 | 11:46 AM
Caroline Roy
Ok so update today i unpluged what i belive is the icp sensor and still no start
