Well boys thanks to all u guys i might have found my problem i give a little pull on my icp plug and the plug part on the sensor fell off with the harness attached to it ill change it and keep u posted
The insulation on the wire. It can get mushy from the oil
of even fall off. With the ICP unplugged you should be able
to start it. The PCM will do a default pressure if it can't get
the current pressure.
The Pigtail is a repair kit if you do happen to have bad wire.
So today i changed the icp sensor and harness still no start my icp sensor is under the turbo does it make a diffrence the one i put in came out of the valve cover?
