so whats this bulb?
Old Aug 30, 2015 | 09:42 PM
twozzie's Avatar
twozzie
so whats this bulb?
I just removed the dash bezel from my 1979 f100. Behind where the light and washer switch sits is this funky looking bulb with a built in spring clip. It seems to be blue in color but I cant see where the light would shine through on the bezel. I think its part 13466 but what the heck does it do and where can I get a new one?
Old Aug 30, 2015 | 10:19 PM
Heliguy's Avatar
Heliguy
That clips in between the lights and wiper switch and lights up the lights and wiper label on the dash. Mine fell off too when I took it all apart. I scratched my head for a while until I figured it out.
Old Aug 30, 2015 | 10:20 PM
HIO Silver's Avatar
HIO Silver
The springy tangs clip on the back of the instrument bezel to illuminate/backlight the headlight and wiper switch.
Notice that the tangs are the same width as the square hole
Old Aug 30, 2015 | 10:31 PM
bkaul's Avatar
bkaul
Yep, it clips in where HIO and Heliguy noted. As far as replacing the bulb, if you look carefully, you'll notice that what you're looking at is actually two pieces: the bulb socket pushes up inside the housing that has the clip & blue filter. You can remove it, then the bulb removes from the socket.
Old Aug 30, 2015 | 10:58 PM
twozzie's Avatar
twozzie
Ah, got it. I just tried the lights at night (first time) and this bulb doesn't work, neither does the one behind the ALT and Fuel. I assume these are similar type bulbs? or are they part of the circuit panel type thing behind the dash, just need to get in there and dig em out.
Thanks
Old Aug 31, 2015 | 08:53 AM
bkaul's Avatar
bkaul
IIRC, that one is a BA9S bayonet base; the ones on the instrument cluster are type 194.
Old Aug 31, 2015 | 09:17 AM
twozzie's Avatar
twozzie
Superb, thx so much
Old Aug 31, 2015 | 12:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 Bulb Chart
Column left: Scroll down to F100/350.
Old Aug 31, 2015 | 02:31 PM
twozzie's Avatar
twozzie
LED replacements?
Has anyone replaced the std bulb format with LED's?
Old Aug 31, 2015 | 04:10 PM
bkaul's Avatar
bkaul
Yes. HiPo Parts sells them.
1961-79 Ford Truck & Bronco LED Gauge Light Conversion Kits - HiPo Parts Garage
I did mine with the "Elite Series, Factory Color" kit for the instrument panel and added an extra bayonet-base warm white LED for the lights/wipers position and an extra warm white 194 for the heater controls.
Old Aug 31, 2015 | 04:38 PM
twozzie's Avatar
twozzie
So I can't simply swap bulbs for leds? There are direct replacement leds though, hmmm.
Old Aug 31, 2015 | 06:19 PM
bkaul's Avatar
bkaul
Yes, you can - the kit is simply a selection of all the LED bulbs you need for the cluster, with installation instructions. Polarity matters, so be sure to install them in the correct direction...
dustyroad
Oct 18, 2021 12:41 PM
BigSexy78
Feb 11, 2017 08:56 AM
bighatchy
Feb 1, 2012 03:52 PM
atomicjoe23
Feb 24, 2009 01:31 PM
77hb
May 19, 2005 10:12 PM
