injectors
Old Aug 30, 2015 | 09:35 PM
dwf6119's Avatar
dwf6119
injectors
Does anyone know if they have a good set of injectors besides the stock sets and if this will fix the issue with injector problems. Thanks
DW
Old Aug 30, 2015 | 09:53 PM
evan1242's Avatar
evan1242
Need more info on your problem.
Ford remans tend to be the most reliable.
Old Aug 30, 2015 | 09:57 PM
dwf6119's Avatar
dwf6119
OK just was wondering if they had anything better in aftermarket, a friend is buying this truck it's a 2003 F-350 with the 6.0 I haven't seen truck truck yet thank you
Old Aug 30, 2015 | 10:03 PM
78fordman's Avatar
78fordman
injectors
Base fuel pressure is key the injector life. Secondly clean oil and good ficm voltage.
Old Aug 30, 2015 | 10:07 PM
dwf6119's Avatar
dwf6119
OK I'll make sure that he checks psi and follow up on good pmcs thank you
Old Aug 31, 2015 | 12:05 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I think in 2004 the injectors got a special coating on the internal parts that reduced friction and wear. I'm not sure if you order injectors for a 2003 truck if you get the special coating but I would think so. That would be an upgrade from the injectors that came in the truck.
DerekF350disel
6.7L Power Stroke Diesel
50
Feb 25, 2016 09:25 AM
ithaca1230
Feb 27, 2015 06:35 PM
vermilian
Nov 12, 2014 12:03 PM
Iain Innes
Sep 24, 2014 06:50 AM
TN97STROKE
Apr 29, 2008 04:46 PM
