New injector problems
Old Feb 12, 2016 | 05:08 PM
DerekF350disel's Avatar
DerekF350disel
I have a 2016 F350 disel with 2500 miles. It's at the dealer now they are telling me some metal shavings clogged one of the injectors. Has anyone ever heard of this and what should I be looking for?
Old Feb 12, 2016 | 05:44 PM
suzuki0702's Avatar
suzuki0702
HPFP failure..make them replace entire fuel system including all 8 injectors
Old Feb 12, 2016 | 06:06 PM
DerekF350disel
I told them I want all the injectors replaced and they said only one injector was clogged and ford probably won't replace the other injectors
Old Feb 12, 2016 | 06:07 PM
DerekF350disel
What is HPFP ?
Old Feb 12, 2016 | 06:27 PM
radium's Avatar
radium
high presser fuel pump DO NOT TAKE NO FOR AND ANSWER BS ON THEM ALL COULD HAVE BEEN HIT WITH IRON SHAVINGS
Old Feb 12, 2016 | 06:35 PM
senix's Avatar
senix
in addition, new fuel filters and a tank flush is required, along with a flush of all fuel lines.
Push for an extended warranty as well, especially if they won't do the right thing.
I would contact ford cust svc too.
Old Feb 12, 2016 | 09:20 PM
DerekF350disel
The service rep at ford said if any shavings went into any of the other injectors it would have burned up because disel engines run so hot and they are clear except one. Should I contact ford customer service before the dealer officially says they are only replacing only one injector or wait to see what they say ?
Old Feb 13, 2016 | 06:31 AM
senix's Avatar
senix
I would contact them.
those metal shavings would not burn up.
Old Feb 13, 2016 | 03:27 PM
DerekF350disel
Thank you for all the info.
Dose the metal shavings that go through the injectors go into the engine and could that damage the engine?
Old Feb 13, 2016 | 03:39 PM
2civicrr's Avatar
2civicrr
I would think the metal shaving have to be fractions of milimeters. Only time I've read of metal shavings it is because the HPFP self destructed. As others have said, the only way to be sure is a complete overhaul of fuel system like Senix described.
If this was a customer pay (your fault), they would tell you the only way to be sure is complete overhaul.
Old Feb 13, 2016 | 03:42 PM
DerekF350disel
Good point thank you
Old Feb 13, 2016 | 08:19 PM
Desert Don's Avatar
Desert Don
I will agree with the others here.....you need a complete fuel system replacement and flush of all fuel lines, filters, etc. Do not settle for anything less!
Hopefully, they will not find contaminated fuel, because if they do it will be on you. And believe me, they will check!
Old Feb 13, 2016 | 08:24 PM
22rimfire's Avatar
22rimfire
Make them tell you where those shavings came from!! I mean, DEMAND they tell you. It came from somewhere in the fuel system, it was their part that caused it, NOT WATER IN THE FUEL! Which is what some are being told is why they won't pay under warranty. Then, when they tell you where the shavings came from you have proof that the fuel system needs replacing. I would be completely flabbergasted if a tech, or service rep told me this was a normal occurance, and replacing one injector is going to take you trouble free down the road. No way. Good luck, and keep us posted.
Old Feb 13, 2016 | 08:34 PM
FishOnOne's Avatar
FishOnOne
I think everyone is jumping the gun based on the OP description of one injector going bad. If the HPFP grenaded the engine would barely run at best.
OP.... Best thing to do is to remove the DFCM fuel filter and inspect for metal shavings. If not your HPFP fuel system is most likely ok.
Old Feb 13, 2016 | 09:16 PM
DerekF350disel
The check engine light came on so I brought to them my truck seemed to be running fine. They tested the fuel and it was fine and they found metal shavings in one injector which clogged it so they said the other injectors compensated for it so Monday they are going to take it apart to find out what caused it he said he thinks it has to do with the high pressure line but not sure
