window seals
Old Aug 25, 2015 | 11:36 AM
mauser9's Avatar
mauser9
window seals
So I ordered a anti rattler kit from Mac's (unwise move, I think), and the division bar requires assembly. You have to move the brackets from your old one, and install the new vent window seal. They send 2 bags of rivets, one with smaller, one with larger rivets. The small rivets will fit into the vent window seal and seat, but the aligning holes in the division bar channel are way larger. Larger in the way that if you were to turn the rivet around and go into the channel first, it completely passes through. I can't see how, by passing through the seal first, I could hammer the post end so that it was larger than the flat end of the rivet, and hold the seal in place. It appears that both size rivets would work for the brackets, so I could use the larger ones for the vent seal, but that would require drilling the holes in the seal larger. I can't imagine that this is correct. Finding someone at Mac's who knows anything has proven difficult.
Any thoughts???????
I know this description is awkward, let me know if you need clarification.
Old Nov 21, 2015 | 06:36 PM
scoobyvanjack's Avatar
scoobyvanjack
Check alarmmedic posting from around 11/3/2013 he indicates a pdf file with a tutorial on rebuilding the front door windows/vent glass and seals/fuzzies etc...
cashman2310
Feb 26, 2016 04:46 PM
badger_hound
15
Feb 17, 2016 06:59 PM
Connecticut Calvin
Nov 3, 2015 06:07 PM
keisha9
Feb 12, 2011 05:59 PM
freperry
Apr 19, 2007 03:51 PM
