One piece drive shaft
Old Aug 24, 2015 | 11:26 PM
BigB6958's Avatar
BigB6958
I've seen a few pics on here of folks replacing the two piece shaft with a single driveshaft. Is that just something I can get built (any tranny/drivetrain shop) or is there some specific places you guys can recommend I contact? Looking for opinions on this swap too. Thanks!
Brad
Old Aug 25, 2015 | 05:26 AM
jowilker's Avatar
jowilker
Brad, I went to a 1 piece when I did my upgrades a few years back. Any local driveline shop should make it happen for you. No issues so far. They are all 1 piece today.
John
Old Aug 25, 2015 | 10:18 PM
john jamieson's Avatar
john jamieson
Are there any advantages to converting to a one piece shaft?
Old Aug 25, 2015 | 11:58 PM
62fordF250's Avatar
62fordF250
Less moving parts to fail/maintain for one. Less expensive to replace for another. You'll have to make sure your slip yoke on the transmission end is long enough or the DS will fall off at max suspension travel.
Old Aug 27, 2015 | 12:07 PM
threepointtwo's Avatar
threepointtwo
I went to a local driveline shop (Slyco) and had them build one for me.
Old Aug 28, 2015 | 03:45 PM
charliemccraney's Avatar
charliemccraney
There is a disadvantage, which is the maximum rpm at which it can operate safely.
I remember when I had my driveshaft made, for use with the stock 3 speed in a swb, the company that made it recommended that I don't operate it above 4500rpm. When I installed the T5, it became short enough that the max was well over 6000rpm. I don't remember how much the change in length was, but it was less then a foot.
For street use, either of these scenarios should be fine but on a LWB, it could reduce that rpm to a point that it really is not usable.
Old Aug 28, 2015 | 04:04 PM
raytasch's Avatar
raytasch
Believe Nothing
Any good driveshaft shop will build your DS with these length and diameter vs speed ratios in mind.
Old Aug 28, 2015 | 05:23 PM
hiball3985's Avatar
hiball3985
Interesting, I have never seen shaft with the slip yoke at the differential end, is this how later model trucks are?
IBleedOvalBlue
Jun 11, 2011 12:31 AM
87F250Lariat
Mar 16, 2011 11:02 AM
aceltx09
Aug 4, 2010 08:29 PM
custom cabby
Apr 7, 2008 11:02 AM
65comet
Feb 9, 2005 01:20 AM
